Single-biwire for LSi25s?
aat
Hi experts,
Does it worth to spend extra money to single-biwire the LSi25s?
Thanks,
AAT
Thanks,
AAT
Post edited by aat on
They aren't really biwire-able in the normal case for biwiring. The bottom posts only feed the powered sub, so there isn't a way to separate the signal between the mids and tweets like you can on the 15s or 9s.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
That means I can only use single-wire speaker cables for the LSi25s.
You can biwire if you want, but normally, biwiring is done to separate the signal from mids and tweeter from being amped together. This can't happen on the 25s since they are a quasi 3way design.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thanks for all the response guys.
