Single-biwire for LSi25s?
aat
aat Posts: 45
Hi experts,
Does it worth to spend extra money to single-biwire the LSi25s?
Thanks,
AAT
Post edited by aat on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2006
    They aren't really biwire-able in the normal case for biwiring. The bottom posts only feed the powered sub, so there isn't a way to separate the signal between the mids and tweets like you can on the 15s or 9s.
  • aat
    aat Posts: 45
    edited March 2006
    That means I can only use single-wire speaker cables for the LSi25s.
  • Dennis Gardner
    edited March 2006
    You can biwire if you want, but normally, biwiring is done to separate the signal from mids and tweeter from being amped together. This can't happen on the 25s since they are a quasi 3way design.
  • aat
    aat Posts: 45
    edited March 2006
    Thanks for all the response guys.
