I was just sitting here pondering...
ND13
on what actually made the most improvement in my system, other than speakers. I know Jesse will say that his source made the the biggest improvement in his, but I guess that would have to do from what you started with as a source. In my rig, the biggest, bestest, and most noticeable improvement came the day I put the ELP inline. It was night and day. Don't get me wrong, I'm a firm believer in having a strong source and the Sheng Ya did make an improvement. The thing is, my AMC CD8b that I got from Sean was modded with upgraded dacs and opamps, so it was already a well above average source and I'm pretty sure that I'll always keep it around for the second rig or as a backup if needed. There's no way I can come close to it's performance for what I have in it.
So, getting to the point....
other than speakers, what piece of gear made the most dramatic improvement to your 2-channel rig? I'm not really wanting to know about your HTs, no offense. This is about reproducing music, not soundtracks.
"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
Post edited by ND13 on
First, came my Carver M-1.5t... Prior to it, I'd never owned more than 50 wpc. The authority the Carver brought was jaw-dropping. My current Sunfire is more refined, but the move to it produced a more subtle improvement.
Second, came my SRS's. They replaced a pair of mid-line Yammie speakers (still around). 'Nuff said...
Third, came my dbx 3BX-III. This little expander is a magic box. It brings dynamics to LP's, cassettes and even FM, that are compromised out of these media.
Fourth, came my B&K AVP 2000. It replaced a "nice" Yammie pre. When I first heard the B&K in my rig, it was like a veil was lifted off of my system. Detail, warmth, soundstage all improved dramatically.
If I have to choose among the above four, it's tough, but I'd go with the Carver experience. There's just no substitute for gobs of reserve power/ current.
Adding other speakers, e.g., Maggies and CA's, have produced more recent ear-to-ear grins. Some roll tubes... I roll speakers.
Many of the added electronics, i.e., pre's, amps, DAC's, TT's, etc., through the years have produced a smile here and there, but again, more subtle changes.More later,
Tour...
Vox Copuli
My tube amp had a great impact. Then the pre amp (Dodd MLP), then the source (Ah with upsampler). Surprisingly, the old Adcom GCD-575 CDP I had did very well.
The Sheng Ya is a great CDP. Just have the correct tube in the back socket (12AX7/12AU7, for power supply) and the 6922 or equivalent in the winder (I know, window). 6922's burn bright back there. No sound degredation but tube life would be short. The Sheng Ya is on par with my Ah! with upsampler which sounds as good as a Parasound Transport/Ultra 2000 DAC combo.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote:My tube amp had a great impact. Then the pre amp (Dodd MLP), then the source (Ah with upsampler). Surprisingly, the old Adcom GCD-575 CDP I had did very well.
Thanks to Victor and Rich for doing a little research on the tube complement for the Sheng Ya/Kavent/Vincent CDP. Who'd figure that the manufacturers site would be wrong, huh?? I just put the hood back on the cdp and put an Ei Elite 12AX7 in the power stage(winder) and a gold pin Amperex 7308 in the output stage. I've been wanting to utilize that tube forever and never did, because I THOUGHT I didn't have anything that only took one 6922.6DJ8/7308. So I should be hearing an improvement in afew more minutes of warm up time, hopefully."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
I knew something was up when he had me check it out and I found the rear tube (power supply) had twice the voltage as the window tube (output stage). Triode tubes contains two fully functioning tubes, so if you have a 1/2 bad tube in either location, you will lose one channel. I popped an EI 12AX7 in the power supply socket and lost the right channel. Tried another tube and it came back. Scary stuff, Victor would never forgive me if I screwed it up.:eek:
It shows that running two channels out of one tube works fine. Cut's your tube rolling costs by 50% too.:cool:
EDIT: It appears you can get a Sheng Ya (or Vincent) where the front tube in the winder is the power supply tube and a 6922 will glow cherry red if it's in that location. I woulda figured they would all be wired the same. Thanks for the info Victor.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
For me, it has to be the source, and strongly believed in modded source, be it DVD player/universal/CDP. One modder whom I have a lot of confidence in, is Alex Peychev. I have two of his products, and saving my coins for his next level.
aplhifi.comI am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Outboard DAC 1st biggest imrovement, 2nd biggest improvement was taking time to place the speakers properly and finally, cables made a nice subtle but noticeable change. I tend to be set in my ways, but just changing things up with the cables and placement really gave my system new life. I feel right now I am at the limit of my RTA's.
Next upgrade will be new speakers and then different amplification and then different pre. That's the order I'd like to do it in, but depends on what deals come first. I'm gonna try to do it in steps so I can evaluate each change independent of the other.
For me, the introduction of a tube integrated amp made the biggest difference, by far. Next, the source (tube CDP), then speakers.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
It all started quite by accident. I happened to be behind my rig and noticed the tube in the back glowing brighter than the one in the front. The positions of the the tubes are different on my Kavent and my Sheng Ya. My Sheng Ya has the 6V tube in the back and the 12V tube is up front - whereas my Kavent has it reversed. When I noticed the tube glowing I asked Rich to check it out. A week later I bought the Kavent, noticed the same problem & thought it was too much of a coincidence so I contacted the manufacturer. I couldn't do it with the Sheng Ya since it is made in China but the Kavent is a Vincent/Sheng Ya imported to the USA and modified by Kavent @ KAVD. One e-mail to them and the mystery was solved.ND13 wrote:Thanks to Victor and Rich for doing a little research on the tube complement for the Sheng Ya/Kavent/Vincent CDP.
They didn't have it wrong - the specs state that the CDP has a 6922/6dj8 tube output - which it does. The 12V is for the power supply - they just "forgot" to mention that :eek: Maybe it was lost in the translationND13 wrote:Who'd figure that the manufacturers site would be wrong, huh??
Now to the original question:
For me it all happened in stages. I got an improvement EVERY time I made a change.- Rotel separates > Onkyo Integra receiver
- AMP:Parasound Halo A23 > Rotel 980BX
- IC's:Signal Cable Analog Two's > AQ Sidewinder's
- CDP:Sheng Ya CD-S10 > Kenwood DP-5070
Speakers - I started my Polk journey with R50's and I've tried Monitor 10A's (Peerless), 10B's, Monitor 11's (Peerless), RTA 11T's (upgraded), to RTA 15TL's (upgraded) with a brief experiment with some Carver AL III +'s.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
I was typing my reply when you edited the info budSCompRacer wrote:EDIT: It appears you can get a Sheng Ya (or Vincent) where the front tube in the winder is the power supply tube and a 6922 will glow cherry red if it's in that location. I woulda figured they would all be wired the same. Thanks for the info Victor.
Thanks for all the help BTW
Going to separate amps (Audiosource Amp Threes monobridged) from a receiver (Pioneer Elite 45TX) to power my LS90s.
Yep, they're entry-level amps. But even so, the dynamics, transients, separation, bass slam and control were significantly improved - music sounds more alive and forceful.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
I know you said no HT. BUT, i now ACTUALLY use my HT rig for 2 ch listening.
Two weeks ago i got an Outlaw Audio 990 pre amp. I have been re-listening to my CD's again.. (in 2 ch. bypass/stereo) just to hear more out of them again. Going from a receiver to this pre amp has made more difference/improvement than any other piece of gear i've ever purchased new or used.
I know others will say source.. but for me. it's been the pre amp. The pre amp made everything ELSE sound better. I always thought my Marantz 4300 CD was a piece of doo doo.. now I know it's not. It was my crappy receiver that was holding back the entire system. No matter what source.. hands down it's the pre amp IMHO that will make the biggest difference in a system. (assuming your system is seperates).PolkFest 2012, who's going>?
You aren't there yet broheiney9 wrote:I feel right now I am at the limit of my RTA's.
Give the silk domes a try and rebuild those x-over's. New speakers they will be
:eek:heiney9 wrote:Next upgrade will be new speakers H9
:mad: See above Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
going to tube pre's made a huge difference in my mind. it just gave me the sound I wanted.
Going the tube cd player route with the Jolida, while not the dollar for dollar best improvement, was a huge step in the right direction for me. It's gonna be a while before source is an issue again for me.
I put the Carver Platinums in third only because it wouldnt help a system without the right equipment. cant just chuck these things on any piece and see a huge improvement. It takes the right stuff behind it, and alot of effort in correct placement to get what you want out of these.
My Carver amp, while fourth, really openned the system's capabilities and performance. Just gobs of good power on tap, and sound is allright by me. Maybe a little to light for the amazings? but emphasis on little, and there are not many speakers that are cheaper than mid size cars this thing wont drive.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Early B. wrote:For me, the introduction of a tube integrated amp made the biggest difference, by far. Next, the source (tube CDP), then speakers.
Same for me. The tube amp started it all by making such a difference.
For me it was going to seperates. In my case, specifically the amp.
My speakers made the biggest improvement, followed by my DAC.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
bobby pin then q-tip, major improvementDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
When I added electricity.
RT1 -
Ok, seriously, well, as serious as I can be today.
The Rig is a by definition a System of interdependant parts. The problems of any System are Systemic to that System.
Therefore:
If the Rig is dependent upon its individual parts
and one of the parts is changed
then the way the parts function together is changed
RT1 -
i cant put a definitive label on which component made the most difference in my two channel rig. it has more to do with how well the sum total of the parts interact with each other. my system has great Synergy and that is why it is hard to put my finger on exactly which component has made the most difference in my rig. everything makes a difference.thanks....WCW IIIRogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
Exactly William. You cannot change any one component without causing change to the entire system.
RT1 -
For me it was speaker placement and acoustic treatment. I use my Ht rig for 2 channel so the next biggest improvement was the Earthquake amp.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
TUBES baby!
I remember getting my Dyna and hearing it for the first time on my LSi9. Sure it wasn't the best synergy but all the good things about tubes soared through the speakers. I can honestly say that it was the first time I heard the mids sound "right" in my system. -
My MF integrated, hands down.
When I stopped wearing pants.
Airplay355 wrote:My MF integrated, hands down.
I hope to experience the high end of SS soon with my LSi9. How many w/ch is your MF?
