quick ? 10 ga for surround wires
doggie750
doggie750 Posts: 1,160
If i have extra 10 ga wires, would it be beneficial if I use it as surround wires. This are inwall wirings.... Please advise. I am currently doing my dad's HT.
Should I spend xtra$$ for 14-16 GA wires.
Much thanks
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
Post edited by doggie750 on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2006
    quick, charge dad for them and buy yourself something else.
    10 guage is a bit much for surrounds, 14 is more than adequate for HT unless you have a loooooooooooooooooooooooooooooooooooooong run say all the way around the house.
    RT1
  • MrNightly
    MrNightly Posts: 3,370
    edited March 2006
    is 50ft of wire considered a long run? I just picked up some RCA digital cable 14gauge for my rears, and got a 100' spool. I was going to just cut the 100' into 50' lengths, and use those for the surrounds. IS that ok?
    Is Digital cable good or bad? Dirt cheap at HD today, couldn't pass it up! :)
    Honoured to be, an original SOPA founding member
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    SVS PB12-NSD/2 - sub :D:D:D
    Denon 3805
    Rotel RB-985 5-Channel Amplifier
  • mantis
    mantis Posts: 17,381
    edited March 2006
    12 guage is fine. It's a bit heavy for surround duty but if you already have it, use it. Can't hurt.
    I perfer 14-2 or 14-4 for rears depending if they are bi wirable or not. Thats what I use. my runs are about 30 fett or so each and it works great. I run my rears in small and cross them at 60hz.
    Dan
    Dan
  • McLoki
    McLoki Posts: 5,231
    edited March 2006
    10 guage, while not neccesary for surrounds, will work fine. Before you try to run 10ga. wire in-wall - make sure it will fit in your planned binding posts. LSi speakers will fit it, but I don't think the RTi's will.
    Worth a test to see if they will fit prior to running the wire.
    Michael
    BTW - I would go ahead and run 12 guage if the 10guage does not work. Again - it would be overkill as well, but most binding posts will fit 12 guage and since it is in-wall, you won't have to worry about it again.
  • John K.
    John K. Posts: 822
    edited March 2006
    Nightly, your 14ga wire should be fine for your 50' runs. A useful table of suggested maximum lengths is found in this article , which is also valuable in its entirety for the factual information it contains relating to the fantasy world created about wire by sellers and naive listeners who think that subjective impressions formed in uncontrolled listening can somehow overturn well-established audio principles.
  • MrNightly
    edited March 2006
    Thanks for the link. Good info in there. I hate using 50footers, but it will help cause it's going down thru the basement than back up to the AVR. Thanks again
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • reeltrouble1
    edited March 2006
    All environments where human listening occurs are uncontrollable. This is a given.
    RT1
