Tsumami wire
dudeinaroom
Has any body had any experience with tsunami speaker wire, I've found some 12 guage in zip cord style, and twisted in a clear palstic over coat, the zip style has a silver, and a coper wire, and the twisted is 2 silver wires @ 49,and 59 cents/foot respectively. so any one know if it's any good?
Post edited by dudeinaroom on
tsunami wire is made by metra, so yes, it is good wire. incase you didnt know, metra is pretty much the leader in mobile audio/video accessories (amp kits, dash kits, and wiring harnesses)
I was just wondering how if faired against home audio wire
Buy a few feet and let us know.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
I run Tsunami wire to my rears (5jr's) in my HT set-up. It is a solid cable. The copper is of a good purity and it is heavy gage. It is probably about equivelant to the same type/grade of monster cable at a lower price point.
I have a 20-25ft or so run to each rear speaker and I have always been pleased with the sound I get from the rears with this cable installed. If you are looking for a solid, low loss, good power handling wire at a low price point, this will do the trick. For the price you can't go wrong.
This wire would also work as an acceptable entry level type of wire to run a pair of mains on. If you search the forums you will also find that some members have had success running home depot heavy gage electrical cord.
BrianThe Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here.
