Tsumami wire
dudeinaroom
dudeinaroom Posts: 3,609
Has any body had any experience with tsunami speaker wire, I've found some 12 guage in zip cord style, and twisted in a clear palstic over coat, the zip style has a silver, and a coper wire, and the twisted is 2 silver wires @ 49,and 59 cents/foot respectively. so any one know if it's any good?
Post edited by dudeinaroom on
  • ThomsRearDeck
    ThomsRearDeck Posts: 1
    edited March 2006
    tsunami wire is made by metra, so yes, it is good wire. incase you didnt know, metra is pretty much the leader in mobile audio/video accessories (amp kits, dash kits, and wiring harnesses)
  • dudeinaroom
    edited March 2006
    I was just wondering how if faired against home audio wire
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited March 2006
    Buy a few feet and let us know.
  • Zen Dragon
    Zen Dragon Posts: 501
    edited March 2006
    I run Tsunami wire to my rears (5jr's) in my HT set-up. It is a solid cable. The copper is of a good purity and it is heavy gage. It is probably about equivelant to the same type/grade of monster cable at a lower price point.
    I have a 20-25ft or so run to each rear speaker and I have always been pleased with the sound I get from the rears with this cable installed. If you are looking for a solid, low loss, good power handling wire at a low price point, this will do the trick. For the price you can't go wrong.
    This wire would also work as an acceptable entry level type of wire to run a pair of mains on. If you search the forums you will also find that some members have had success running home depot heavy gage electrical cord.
    Brian
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    This is pretty f***ed up right here.
