Wall mount
Sthrndream
I need a wall speaker mount for my polk LSI FX that allows me to swivel it 180degrees. I looked at the BT 77 however the FX's width is 13 inches. The speaker points forward from thee rear wall not toward my listening position. I dont have a wall to point one of them at me, thus I need a bracket. Any Suggestions????
TIA
TIA
Post edited by Sthrndream on
You might consider a pendant mount instead of a wall bracket.
