hooking up adcom gfa 555 to rxv2600
ronnie
ronnie Posts: 150
im new here and glad i joined...i need to know what are the best cables to hookup the adcom to my rxv2600. the adcom will be running the woofers in my RTi12's,,.,.,anybody have the same setup. i never had an external amp and not sure what cables to use, i heard blue jeans are a good cable
Yamaha RX-V2600
Adcom GFA555 x 2 :D
Yamaha CD685 cd changer
Yamaha Dvd c950 dvd changer
Polk RTi12 mains
Polk CSi3 center
Polk psw303
Polk RTi6 (surround and surround back)
Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
WindyWillys cooling fan (works great)
Mitsubishi 52in big screen
blue jeans cables
AR interconnects
Post edited by ronnie on
  • george daniel
    george daniel Posts: 12,096
    edited March 2006
    When I had adcom gear I used signal cable speaker cables, not to expensive, good all around solid cable, and Frank@ signal is a pleasure and easy to work/deal with,I believe that he still gives a discount to CP members. Good luck,and Welcome:)
  • ronnie
    ronnie Posts: 150
    edited March 2006
    Thanks Alot For The Info
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • nellis8166
    nellis8166 Posts: 292
    edited March 2006
    I'd check out audioquest as well.
    RTi10
    CSi5
    RTi28
    SVS PB12-ISD2
    Denon 2106(pre/pro)
    Adcom 5503(200x3)
    Audioquest Diamondback ICS
    Kimber Kable 8tc biwire(mains and center)
    "Don't let your silly dreams fall in between the crack of the bed and the wall."
    -J. James
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2006
    Blue Jeans does make good IC's & cables as well, & won't break the bank.
    Welcome, Ronnie!
  • ronnie
    ronnie Posts: 150
    edited March 2006
    thanks for the welcome...i love this place..hey cfrizz..hows that boston sub sound...looking into getting a different sub...right now i have an old acoustic research 12
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • cfrizz
    edited March 2006
    It sounds just fine for my small little place. If I had a SVS I think my walls would cave in!
    It goes BOOM when it should & mixes well with music, which is the most important factor for me.
    My Boston Center also rocks! Once I put the separate amp on it it got nice & clear.
    As you can see, none of my speakers match, but I don't hear anything totally out of whack.
