hooking up adcom gfa 555 to rxv2600
ronnie
im new here and glad i joined...i need to know what are the best cables to hookup the adcom to my rxv2600. the adcom will be running the woofers in my RTi12's,,.,.,anybody have the same setup. i never had an external amp and not sure what cables to use, i heard blue jeans are a good cable
Yamaha RX-V2600
Adcom GFA555 x 2
Yamaha CD685 cd changer
Yamaha Dvd c950 dvd changer
Polk RTi12 mains
Polk CSi3 center
Polk psw303
Polk RTi6 (surround and surround back)
Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
WindyWillys cooling fan (works great)
Mitsubishi 52in big screen
blue jeans cables
AR interconnects
Adcom GFA555 x 2
Polk RTi12 mains
Polk CSi3 center
Polk psw303
blue jeans cables
AR interconnects
Post edited by ronnie on
When I had adcom gear I used signal cable speaker cables, not to expensive, good all around solid cable, and Frank@ signal is a pleasure and easy to work/deal with,I believe that he still gives a discount to CP members. Good luck,and Welcome:)JC approves....he told me so. (F-1 nut)
Thanks Alot For The InfoYamaha RX-V2600
Adcom GFA555 x 2
Polk RTi12 mains
Polk CSi3 center
Polk psw303
blue jeans cables
AR interconnects -
I'd check out audioquest as well.RTi10
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
Audioquest Diamondback ICS
Kimber Kable 8tc biwire(mains and center)
"Don't let your silly dreams fall in between the crack of the bed and the wall."
-J. James -
Blue Jeans does make good IC's & cables as well, & won't break the bank.
Welcome, Ronnie!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
thanks for the welcome...i love this place..hey cfrizz..hows that boston sub sound...looking into getting a different sub...right now i have an old acoustic research 12Yamaha RX-V2600
Adcom GFA555 x 2
Polk RTi12 mains
Polk CSi3 center
Polk psw303
blue jeans cables
AR interconnects -
It sounds just fine for my small little place. If I had a SVS I think my walls would cave in!
It goes BOOM when it should & mixes well with music, which is the most important factor for me.
My Boston Center also rocks! Once I put the separate amp on it it got nice & clear.
As you can see, none of my speakers match, but I don't hear anything totally out of whack.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
