Finished Pics Of The Rebuild...Finally
  • Early B.
    Early B. Posts: 7,900
    edited March 2006
    brettw22 wrote:
    For me, visually or not, that texture is not something that I'd ever want on something that I'd have inside my house doing what they'd be doing......to each their own though.
    Actually, with several costs of poly on it, the texture will be fairly smooth. Depending upon the number of coats, the surface could be made smoother than J Lo's ****.
    The value of using truck bed liner is ease of use and durability. Just like any other paint job, if done properly, it can look first class.
    "God grooves with tubes."
