Wire guage
I am running speaker wire about 45 feet to another room from my home amp. What size wire do I need to run?
lhill@terraworld.net
Post edited by 70445 on
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
I would use the 12 guage speaker wire from Lowe's or Home Depot. About $ 0.45/ft.Carl
Yeah, for that length you need to go at least 14 gague. Folks at places like CC and BB will tell you 16 is ok, but I don't buy it.Harman Kardan AVR 630
Sony DVPNS665 DVD
Polk TB 90 Front Mains
Polk CsI3 Center
Polk FxI3 Surrounds
Velodyne VX-10 -
I'm using 12 gauge wire from Home Depot for some 60ft runs to the mains and center channel and am very happy with it.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
stranded speaker wire for about 40 cents a foot.
Good deal, and very good wire.
Search the forums for banana plugs. I posted some plugs that I got off of Ebay that are military grade, built-like-a-tank plugs.
Put 'em together, and you're good to go.Sal Palooza
