How high to hang rears?
anandrag
anandrag Posts: 6
Have the R15s for rears. How high to hang them? Will be above sofa
Post edited by anandrag on
  • mantis
    mantis Posts: 17,422
    edited February 2006
    They should be 72 inches to the tweeter.
    Dan
    Dan
  • anandrag
    anandrag Posts: 6
    Dan
  • amulford
    amulford Posts: 5,020
    If you look at the speaker w/ the grill off, you will see a smaller driver. That's the tweeter. 6' off the floor to that.
  • michael_w
    michael_w Posts: 2,813
    I usually stick em about three feet above ear level firing at each other on opposite walls.... six feet would work well too.
  • andersonbc
    andersonbc Posts: 9
    I have some FXi3's mounted up around 8 feet (due to room limitations). Do you think it would be benificial to tilt them in any way?
    RTi10's, CSi5, FXi3's, PSW505
  • mldennison
    mldennison Posts: 307
    might help but not sure it will bring all that much benefit since they are not up all that high. if they are on stands i would try propping the back of the speaker a little and see if you hear any difference. just dont do it too much :eek:
  • danger boy
    danger boy Posts: 15,722
    no tilting needed. those FX's send the audio in two different directions.. they are built that way.. unlike forward firing speakers.. so tilting them isn't going to help any.
    PolkFest 2012, who's going>?
  • andersonbc
    andersonbc Posts: 9
    Thanks for your reply. If you guys don't think they are mounted too high I won't worry about. They sound fine, but I'm always wondering if things can be better!
    Oh, and on the tilting, I should have explained what I was thinking better. I was thinking about tilting them so that the front side (speakers facing the tv) would be tilted slightly downward (they are wall mounted).
  • danger boy
    unlike your fronts, where you want the tweeter are ear level.. fx speakers you want them to send the audio over your head. I know that sounds **** backwards, but that's going to give you the best sound from them. you don't want your fx to low.
  • Eric W
    Eric W Posts: 556
    edited March 2006
    Approximately 6 feet off the ground usually works best for surround speakers.
    -Eric
    -Polk Audio
  • buyitnow
    buyitnow Posts: 18
    edited March 2006
    I don't have a back wall; my room is open to the kitchen and so my back is to the kitchen as well. I had my house pre-wired through our builder (5.1)before fully educating myself on surround.
    Anyhow I have two speaker wires hanging from the ceiling for my rear speakers. I've bought ceiling Omnimounts for my RM6800's. What should I expect from this rear ceiling setup and how can I maximize (if at all) the setup? The cieling is 9ft and the speakers will be almost directly over my head. Should I face speakers down towards my ears or not? Any help will suffice since I'm pretty stuck in the placement of these rears.
    FONT="Tahoma"][/FONT]Room size: 18x14
    RM6800
    Harmon Kardon AVR235
    56' Samsung DLP
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited March 2006
    Mine are at bout 5'10" at the bottom of the speaker.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • John K.
    John K. Posts: 822
    edited March 2006
    Buyitnow, welcome. If these are your side surround speakers in a 5.1 setup you should attempt to have the sound coming at you from the side rather than overhead. Experiment with aiming the speakers at the side walls so that the sound will then be reflected toward your listening position.
  • wingnut4772
    edited March 2006
    My rears are in the ceiling and it works out just fine but I suppose that optimally lower might be better for them?? The tweeter is aimable and the woofer is angled toward the listening position.I have no complaints.
    Surround Height
    More
    Just Google Surround Placement Height.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • buyitnow
    buyitnow Posts: 18
    edited March 2006
    Thanks for the replies and links.
    My next question of many to come I'm sure. My speaker wires for front left and right speakers are protruding from front wall at about 7' from floor and 2' from celing. I don't want my speakers that high, plus my entertainment center would block them because it is about 8' tall. I want to set up my RM6800 fronts on the book shelfs at about ear level (sitting down) by running the speaker wire through holes i will create behind the entertainment center. Problem is the speaker wire from the wall may not reach the speaker placement I want.
    Question: Is there a way to "extend" the speaker wire? Or use some kind of extension method?
    Hope my situation is clear. Appreciate any help.
    thanks
    RM6800
    56' Samsung DLP
