How steady is your hand?
:eek: Dayum
Hmm---- alright so you can easily do straight lines by right clicking then moving to where you want to end up and just left clicking... it jumps across the page and works as long as you don't cross one of the borders in the jump. To get really sneaky when you get to the third level you can just right click and zoom in so that the little square you control is pretty much the size of the screen. Just click and hold to pan and then move a little, pan again... yea you get the point.... yes...
You can try creating an account with admin privilages... not sure if it would work or if they'd be too happy if you did it but you might be able to do it this way.Ron-P wrote:F'ing Sonic Wall. Computer tech guy was in last week and now I can't access sheet like I used to. Anyway to bypass this thing...or kill it?
Go to Run and type cmd. You should get a dos prompt. If it's disabled theres ways around that but lets assume it's not. From there you'd type net user newaccountname newaccountpassword /add. Hit enter and it should say something like "The command completed successfully". From there you'd type net localgroup "administrators" /add newaccountname.
Voila. You have an account on that computer with full admin privilages. I've never tested this while logged onto an account with restricted access though so it might not let you create an account. Use at your own discretion since I'm sure if they found out you were doing this they'd think you were planning something evil or harmful to the company, and not just wanting to play some games. -
Thanks for the tip Michael. Not sure if that's something I'll try or not.If...
Ron loves a film = don't even rent.
