Optical cable for $40-$50...What to buy?
MSkeezer
MSkeezer Posts: 1,183
edited February 2006 in Electronics
I purchased a Denon 1720 a couple of days ago, and was "conned" into a buying a $60 Monster Lightspeed 200 optical cable. I let my guard down, what can I say? The Denon is a great player and I got it for a good price, but I feel like I can do better when it comes to the cable, especially for that price. Anyone have any suggestions?
Post edited by MSkeezer on
  • danger boy
    danger boy Posts: 15,722
    check out this optical cable on Ebay. Very well made and usually half the price of Monster cables.
    Another good cable is Cobalt Cable optical both of these companies are local to me.. and i've meet with the designers of both. I know both are high end, high quality cables. I've seen and use their products in my home theater and 2 ch. system.
    PolkFest 2012, who's going>?
  • MSkeezer
    I like that Raymond cable. I'm going to be watching that one. The Cobalt looks like a great option, too.
  • tryrrthg
    tryrrthg Posts: 1,896
    Check out DH labs cables. They make some very nice cables at a decent price.
    http://silversonic.com/docs/products/Toslink.html
    You can buy the toslink here:
    http://audioc.com/accessories1/dhlabs/toslink.htm
  • Skynut
    Skynut Posts: 2,967
    +1 for the Raymond cable.
    I have this one in my system and like the build quality.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • halo
    halo Posts: 5,616
    Audioquest / Cinemaquest - I'm using the OptiLink-G and I'm very happy with it.
  • dragon1952
    dragon1952 Posts: 4,907
    How long do you need? I might have one lying around. Also, have you considered using a digital coax? You can get a real nice one for around $20.
  • aaharvel
    aaharvel Posts: 4,489
    what's wrong with the one you have? I mean these things transfer light- what's the difference? The one you already have seems nice.. i could be wrong
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • danger boy
    yes you could. :p
  • MSkeezer
    Nothing wrong with it. It does a great job, but I thought I could do better for less. And I do hate giving Noel $60 to pay for legal fees :p
    I've tried a coax, but I get some distortion on the screen. Lines that appear diagonally in the picture. I'm guessing because the dvd player is next to the cable box and the line coming in from the wall. I don't get that when using optical...
  • WilliamM2
    WilliamM2 Posts: 4,807
    Radio Shack has a Fusion style optical cable, really heavy duty with nice connectors. $14.95
    http://www.radioshack.com/product/index.jsp?productId=2062041&cp=&kw=optical&parentPage=search
    They have 6ft. and 12ft. for a little more $.
  • aaharvel
    now imo that's a very good buy.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • MSkeezer
    Accessories For Less has that cable for $4.00.
    http://www.accessories4less.com/cgi-bin/item/RS1501091
    I may even stock up on some of those...
  • dkg999
    dkg999 Posts: 5,647
    I went from a Monster 200 series optical cable to an Outlaw Audio optical cable and I still maintain that the sound opened up and is much better. I know, as was pointed out on these forums, that it is technically impossible. It's all light representing 1's and 0's. Doesn't change what I think I hear :confused:
    DKG999
  • steveinaz
    steveinaz Posts: 19,545
    DH Labs toslink, best bang for the buck IMO.
  • WilliamM2
    For $4 I think you found your solution, as long as shipping isn't bad.
    I have 3 of those cables, great build quality, solid metal connectors. The ones at my local RS look the same as AC4Less, not the picture in the link I posted above.
  • aaharvel
    i really like the Fusions. I use them for everything, much better quality than Monster STD although that's not saying much.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • mantis
    mantis Posts: 17,365
    The monstercable optical you have is fine. Basically optial cables are very close but what I found about better quality cable is the finish end. the connector locks in better. the cheaper ones seem to fit loose.
    You will not gain any performance getting a better cable. No sound quality difference.
    Dan
    Dan
  • John K.
    John K. Posts: 822
    MS, sure there's nothing technically wrong with the monster, but you're right to want to avoid paying Noel(probably the major culprit in starting the wire and cable nonsense that pollutes audio today)his rip-off prices. The Ac.4Less would be a good buy or this similarly good buy with lower shipping charges.
  • drew spelts
    drew spelts Posts: 310
    yeah they were clearencing some nice cool looking philips brand optical cables out at wallmart one day and I snagged them all up. I still have one in the original box I think. The only difference as stated above will be the quality of the connection not the transmission of information. Heck I just use the digital coaxial cable because I think it sounds maby better but the sound never dropps out like it has from my DVD player to my receiver like it would with the optical cable. Its a crappy DVD player, probably worth $10 now. LOL. So thats why I use the Dig-Coax.
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
  • MSkeezer
    Thanks for all the suggestions, guys. I still haven't decided what to go with. Give me a couple of days :p I may just keep the Monster cable just so I don't have to go through the hassel of returning it. But then again, there are some great options out there and they all cost less than the Monster. I will at least stock up on those Fusion cables from Ac.FLess. You never know when those might come in handy :D
  • StopherJJ1980
    StopherJJ1980 Posts: 267
    When I bought my first AVR and speakers for HT years ago at Best Buy I was a newbie and let the guy talk me into buying the $50 monster optical cable I 'needed'. When I went to check out the lady missed it in the cart as the other stuff was covering it up so I ended up getting it for free. So I look back on it as an ironic tale of karma, BB upselling me an overpriced monster cable but getting burned in the end for it.
    Having said that, it has worked fine for me and have never been able to tell the difference between this an any other quality cable. I figure optical cables are the definition of the law of diminishing returns. As the poster above pointed out an optical cable passes light signals. Light is light. There is no "high quality light". Sure there are crappy optical cables out there but just pay at least 15-20 bucks and you should be fine. Beyond that light cant be transferred any better or more accurate.
    Sure some people can sell their snake oil when it comes to cables passing electric current, but here I think optical cables should be a no brainer.
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
  • danger boy
    although you got your Monster optical cable for free... you were in fact willing to pay $50 for it.. but you got it free instead. so if optical cables are all the same in your opinion, why then were you prepared to pay so much for it? Why did you choose Monster cable and not brand X while in the store?
    I know the answer.. everyone loves Monster cables.. because they are better than all the rest right?
  • halo
    halo Posts: 5,616
    db - I think he chose it because he was a newbie that bought into the hard sell from BB. Like he said:
    :eek: :p;)
  • MSkeezer
    I hate salesmen. The guy who sold me my Denon was great(that's why I hate him :p ). He answered all of my questions, he knew his stuff. I knew I f***ed up when I asked him about cables, cuz if there was one thing he was good at selling, it was that. I was the one who left with a $60 Monster optical cable. THAT is how good of a salesman he was. I've seen him in action before, and I used to feel bad for his "victims" lol. He does particuarly well with the ladies. He's attractive, charming, and he asks questions. The ladies love that. Hell, I should just keep the cable now :D I think I owe him that lol.
  • StopherJJ1980
    As Halo was so generous to point out already, yes, At the time I got it because the guy handed it to me and said "Here, you'll need this if you want the 5.1 surround". I didnt choose it, I didnt even know I had a a brand choice at the time as it was the only brand I saw on their shelf at the time. If I could go back with what I know now I wouldnt get it.
    Read carefully what someone says before you make smug critiques about it :)
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Yamaha HTR-5740 AVR
  • StopherJJ1980
    LOL sounds all too familiar. I was at best buy a couple months ago and a lady was buying a new big screen HDTV. The sales man was literally piling up Monster products she "needed" to go with her TV. After you figured in a Monster power center, HDMI, and other cables she must've had 500 bucks worth of stuff added on. She was very nonchalant about it too (she looked liked she didnt care with the prada shoes and Gucci glasses and Luois Vuitton purse etc). I was almost going to say something to her but I had a moral dilemma of watching someone getting upsold enneccesarily versus stepping in and possibly ruining the guys commission.
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Yamaha HTR-5740 AVR
  • danger boy
    enjoy your Monster cable. :p
  • HiPerf360
    HiPerf360 Posts: 436
    The "spiffs" are insane to the salesmen for selling Monster Cable at places where the salesmen are on commission.
    I have some monster stuff as the price was right, less than 1/2 msrp through a friend at Ultimate Electronics.
    But after learning of the strong arm tactics MC uses I will no longer buy anything from them.
  • MSkeezer
    Update:
    The Monster cable is a piece of s***. I tried pulling it out of the back of my dvd player and the connector broke off. WTF? Did I really spend $60 on this POS?! It's going back tomorrow and I swear to never buy another Monster product.
    I did pick an optical cable from Better Cables and so far I'm very impressed. It was cheaper than the Monster but it sounds just as good and it doesn't look it's going to break anytime soon.
    Again, thanks to everyone for all of the suggestions.
