Surround Speaker Questions
smalltownheel
smalltownheel Posts: 39
Is it ok to use a smaller guage wire for my LSiFXs than I'm using for my LSi15s. I'm using 14 guage for the 15s and want to use 18 for the FXs. Should I bi-wire the FXs? And does the length of the wire runs for the FXs matter much?
Post edited by smalltownheel on
  • danger boy
    danger boy Posts: 15,722
    edited February 2006
    don't bother with bi wiring your LSiFX's.
    you can use 18 guage wire for surrounds.. but me, i like to keep things consistant.. so i use 14 guage for fronts and surrounds.
    length of wire in a home theater set up does not matter. It would only matter if the length of cable was very long.. so 150+ feet. don't worry about cable length at all.
    good luck. sounds like a fun project. get those things wired, and fire em up!!
    PolkFest 2012, who's going>?
  • okiepolkie
    okiepolkie Posts: 2,258
    Here is a good website to hlep determine if what gauge will be adequate for each length: http://www.roger-russell.com/wire/wire.htm.
    The article is good, but the chart is definitly a solid reference.
    Tschüss
    Zach
  • schwarcw
    schwarcw Posts: 7,360
    Thanks for the info Zach! Interesting table for wire and other stuff.
    Carl
  • wingnut4772
    wingnut4772 Posts: 7,519
    I have 14 guage for my surrounds and 10 for my front 3 ( and don't tell anyone ..but the 14 gauge is Monster <gasp!>)
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • okiepolkie
    Tour posted that chart for me about a year ago and it has been helpful in different situations.
    Tschüss
    Zach
  • smalltownheel
    Thanks okie for the link, very helpful. And I think I'll not worry about bi wiring. I was going to mount the FXs about three feet above listening level straight into wall studs. Good route, or should I try speaker mounts? And if I should go speaker mounts, which ones would you recommend?
  • okiepolkie
    Directly into the studs would be your best bet. Mounting those speakers on brackets would be okay, but it probably won't make a large difference.
    Tschüss
    Zach
  • danger boy
    straight into the wall, stud! :p
    and three feet above your seat is great. Will they be mounted on a side wall or rear wall?
  • smalltownheel
    rear wall
