Surround Speaker Questions
smalltownheel
Is it ok to use a smaller guage wire for my LSiFXs than I'm using for my LSi15s. I'm using 14 guage for the 15s and want to use 18 for the FXs. Should I bi-wire the FXs? And does the length of the wire runs for the FXs matter much?
Post edited by smalltownheel on
don't bother with bi wiring your LSiFX's.
you can use 18 guage wire for surrounds.. but me, i like to keep things consistant.. so i use 14 guage for fronts and surrounds.
length of wire in a home theater set up does not matter. It would only matter if the length of cable was very long.. so 150+ feet. don't worry about cable length at all.
good luck. sounds like a fun project. get those things wired, and fire em up!!PolkFest 2012, who's going>?
Here is a good website to hlep determine if what gauge will be adequate for each length: http://www.roger-russell.com/wire/wire.htm.
The article is good, but the chart is definitly a solid reference.Tschüss
Zach -
Thanks for the info Zach! Interesting table for wire and other stuff.Carl
I have 14 guage for my surrounds and 10 for my front 3 ( and don't tell anyone ..but the 14 gauge is Monster <gasp!>)Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Tour posted that chart for me about a year ago and it has been helpful in different situations.Tschüss
Zach -
Thanks okie for the link, very helpful. And I think I'll not worry about bi wiring. I was going to mount the FXs about three feet above listening level straight into wall studs. Good route, or should I try speaker mounts? And if I should go speaker mounts, which ones would you recommend?
Directly into the studs would be your best bet. Mounting those speakers on brackets would be okay, but it probably won't make a large difference.Tschüss
Zach -
straight into the wall, stud!
and three feet above your seat is great. Will they be mounted on a side wall or rear wall?PolkFest 2012, who's going>?
rear wall
