PS Audio XStream Power Punch - The Silk Panties of power cords?
RuSsMaN
RuSsMaN Posts: 17,986
edited May 2007 in 2 Channel Audio
Not because they are soft, and feel nice against your bum, but rather due to the fact one may actually have some beads and shells left over, for other finer things in life.
I've been intrigued by PS Audio's Power Punch offering. Looking at the price (around $70 for a 2m cord), I honestly was not expecting much. Probably a standard IEC cord, wrapped in a nice jacket, with upgraded connectors. I couldn't have been more wrong. How PS Audio can sell (and package) these cords SO cheap, is beyond me. They must truely be a loss leader, the minnow dangling on the hook - to get people to try their products (in hopes if they are pleased, they will upgrade or look at other PS Audio offerings).
I purchased two, 2.0m Power Punch cords a couple weeks ago, and have been burning them in on my single ended 211 monoblocks. (I removed my SC power cords, for the purpose of this review). The difference was anything but subtle (compared to a standard $3 IEC). Overall, the music has more weight, from top to bottom. Every note seems to have just a little more impact, and presence. It's not as though a blanket has been lifted off the system, but rather a fine film was removed. Bass speed and attack has improved slightly also.
My 211 monoblock power trannies crank out over 1000v, so unless you bury them in concrete - there is ALWAYS some noticeable hum from the transformers themselves. As soon as I connected the PS Audio Power Punch cords - the hum was cut by at least 50% - again, comparing directly to your standard IEC. Instant, noticeable difference.
Build? First rate. Very flexible, easy to route, and both ends make a SOLID, confident connection to the outlet and input.
I won't ramble on too much about a entry level product, because, well, that's exactly what it is. However, for a very small investment, the Power Punch offers real performance, at the listening chair.
Is this the cable for everyone? Probably not.
This is the cable for the Audiophile, who expects, nay demands a certain level of performance - but at the same time would like to have a few greenbacks in his/her pocket left over for posh undercrackers.
http://www.psaudio.com/products/xstream_power_punch.asp
Associated gear:
DIY Custom Line Arrays
Signet SP200 Subwoofer
Radii MMS 211 monoblock tube amps (power punch 2m)
Rogue Audio Magnum 66 tube line stage (power punch also, 1m)
AMC CD8b Transport
Meridian 563 D/A converter
Sansui TU-417 Tuna
Cheers,
Russ
Post edited by RuSsMaN on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited February 2006
    Hey Russ,
    I have been using the Power Punch C7 on my Pioneer Elite DV 45A for around 6 months and have found it to be the best (only) solution for that funky connection. I found quite abit more refined soundstage over that stock cord in audio for CD and SACD. Great entry level upgrade for anyone not wanting to break the bank on esoteric power cables.
    If some here can get by with the 1 meter version into their power centers etc. This guy is nearly giving them away on ebay:
    $33 offering of this cable
  • michael_w
    michael_w Posts: 2,813
    Nice review Russ.
    How do you think it stacks up to the SC since they are both in similar price ranges? Also, which signal cable one do you have?
  • dkg999
    dkg999 Posts: 5,647
    Russ - are they comparable to the SC cords? I need a couple more 6' power cords, I might try these if they are comparable or better.
    DKG999
  • RuSsMaN
    I use the MagicPower cords, and MagicPower strips, and have not done a side by side comparison yet, but don't see them being a whole lot different from each other.
    The basic improvement here (again, over a standard IEC) is current delivery, shielding, better parts/termination for a solid, sure connection.
  • Dennis Gardner
    The ground lifting option (the ground pin unscrews) is a cool design in itself. The molded ends are way secure on the PS Audio cords compared to shrink tubing on the Marinco/Wattgate plugs with smaller gauge wiring on some of my other power cables.
    This is the Plus model, but the Punch looks similar.
    heiney9 Posts: 25,419
    Thanks for the indepth Russ. These types of reviews with substance are what it's all about.
  • dkg999
    dkg999 Posts: 5,647
    Russ - thanks for taking the time to write up the review! I might give these a try. It's starting to look like a Signal Cable advertisement around my place. It's good to try something new. Doug.
    DKG999
  • dorokusai
    dorokusai Posts: 25,576
    The Power Punch has been the most reasonably priced PS Audio product for awhile. It's nice they came out with something else for normal people.
  • beardog03
    beardog03 Posts: 5,550
    Normal..?
    what`s that ?!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • RuSsMaN
    A distant memory, a faint stench, a greasy stain - of what we used to be Robert.
  • beardog03
    aaaahhhh !
    rriiiight..!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • unc2701
    unc2701 Posts: 3,587
    Russ
    Thanks for clarifying, but we're still left with the visual of you with a power cord riding up your ****...
    Backburner:Krell KAV-300i
  • marvda1
    marvda1 Posts: 4,941
    Question, i noticed these are nickel plated, irecently posted questions on other forums about upgraded electrical outlets and the number one thing was to get outlets that were not nickel plated but rather brass. so why is nickel plated on the power cords ok?
    Puritan PSM156
  • RuSsMaN
    In my opinion, nickle plating is not a bad thing, as long as everything (outlet included) are nickle plated. You start getting down to the nitty gritty with audiophiles, and certain metals - and it has been proven (to a degree) that going with different metals on connectors, beit speaker wire terminations and binding posts, or wall outlets and power cables - that a miss-match will actually excellerate corrosion.
    I've yet to experience it myself, and I'm somewhat versed in real world cable experience. The fact is, this power cord isn't marketed to the hardcore, it's marketed to the common man - and power outlets are a thing of lore (at this price point - short of a PS Audio Power Port ;) ). That being said, the benefit of proper, tight, solid fit, outweighs the negative of a matching conductors, in my opinion - but you do state a valid point.
    Bascially, it is a concern, but not at this pricepoint.
    Cheers,
    Russ
    F1nut Posts: 51,700
    Another thought on the nickel plating. The IEC sockets on most gear are nickel plated and if one were to upgrade the power outlet(s) to PS Audio's Power Port, then you would have all nickel contacts. No worries, mate.
    BTW, brass oxidizes, nickel doesn't.
  • Ferres
    Ferres Posts: 310
    The audiophile powercords job is to shield, clean and filter out mains noise from coming into the system and muddying the sound. Plating shouldn't be a big issue. :)
    I think of all cable upgrades, the powercord going to the pre-amp should be the first in line.
    I'm looking at Ps Audio cords too since they have a lot more options in space saving connectors.
    Nice review Russman. :D
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • Ricardo
    Ricardo Posts: 10,636
    Nice review, and great tip on the ebay link.... I sent the seller an email asking if connectors were IEC or C7....not specified on the description.
    SOPA
  • wingnut4772
    wingnut4772 Posts: 7,519
    Nice Russ.. I really considered these before I went the Harmonic Technology route but we have to be careful....threads like these may actually give people the impression that power cords do make a difference. ;)
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • madmax
    madmax Posts: 12,434
    Russ, you should pick up on the "Statement" offer if you get the chance before it ends. Half price with the return of an old cable. I wouldn't outfit my whole rig with them because I can't afford it but it is cool to see the one sitting there going to the phono pre. I've been considering some of the Power Punch ones for the other stuff though.
    madmax
    Vinyl, the final frontier...
  • Tour2ma
    Tour2ma Posts: 10,177
    Nice write-up, Russ... Borderline eloquent
    More later,
    Tour...
    Vox Copuli
  • Ricardo
    They are IEC...
    SOPA
  • jfb4548
    jfb4548 Posts: 168
    The Power Punch is hard to beat for the money. It looks great and sound great and the removable ground pin is a plus. If you buy direct from PS the shipping rates seem high. I ordered my second one from MusicDirect and the USP was 1/2.
  • Early B.
    Early B. Posts: 7,900
    Just ordered two of them. One Power Punch will replace my PS Audio Prelude which is too long and bulky for my application. The other one will replace a Custom Power Cord with Furutech connectors. The Power Punch appears to be "downgrade" from what I already have, but the price, length, look and build quality should make up for the differences, if any, in sound quality. If things work out, both cords will be up for sale soon.
    "God grooves with tubes."
  • madmax
    Hey EB, want to sell that Prelude? Which one is it? Sent you a PM.
    madmax
  • tryrrthg
    tryrrthg Posts: 1,896
    Does anyone know the difference between the Super Punch and the Power Punch? Is it just the right angle plug?
    Super Punch
    Power Punch
  • Emlyn
    Emlyn Posts: 4,640
    They're the same cable internally: 12 AWG OFC wire, double shielded. The only difference is in the terminations, with the Super Punch having more expensive wall end plugs.
  • dorokusai
    The SP is also not available in a C7 termination.
  • RuSsMaN
    and....
    Only the C7 has the right angle term.
  • dkg999
    dkg999 Posts: 5,647
    The website says they work for small to mid-size amps. Does a Parasound HCA-1500 qualify as mid-size? The SC power cables appear to be a little heavier guage. Not sure if that really makes a difference?
    DKG999
  • dorokusai
    It's for any amplifier, that's just marketing BS.
