speaker output shifts
zombie boy 2000
this is a relatively minor issue... no real need to jump on it
but i'm inbetween cable and satellite, so i temporarily have my tv hooked up via antenna...
i have the audio defaulted to stereo through the tv's menu, and i've noticed that during certain programs, the output directed to the right channel will (from time to time) "phase over" to the left channel -- creating a momentary, but noticable hole in the stereo presentation
kind of like a brief fluctuation between mono and stereo, with the former "presentation" favoring the left channel
i'm sure this has everything to do with having an antenna hooked up and should be resolved with the addition of a satellite provider, but i'm still curious as to what might be causing this -- as brief and trivial as it might be
thanks for any input
Post edited by zombie boy 2000 on
My T.V. has a built in surround pro. and every now and then it just sounds or does funny things.
The comercial will start off real loud in the surrounds and then fade to the front channel.
Maybe it is the ota signal and the t.v. is just repeating what it heard.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
I could also be signal strength when I was forced to just over air broadcast I used to have the same problem. Got a signal amp and the problem went away as well as the slight gosting, and line in the picture were gone, just my 2 cents worth
