speaker output shifts
zombie boy 2000
zombie boy 2000 Posts: 6,641
edited February 2006 in Troubleshooting
this is a relatively minor issue... no real need to jump on it
but i'm inbetween cable and satellite, so i temporarily have my tv hooked up via antenna...
i have the audio defaulted to stereo through the tv's menu, and i've noticed that during certain programs, the output directed to the right channel will (from time to time) "phase over" to the left channel -- creating a momentary, but noticable hole in the stereo presentation
kind of like a brief fluctuation between mono and stereo, with the former "presentation" favoring the left channel
i'm sure this has everything to do with having an antenna hooked up and should be resolved with the addition of a satellite provider, but i'm still curious as to what might be causing this -- as brief and trivial as it might be
thanks for any input :)
Post edited by zombie boy 2000 on
  • Skynut
    Skynut Posts: 2,967
    My T.V. has a built in surround pro. and every now and then it just sounds or does funny things.
    The comercial will start off real loud in the surrounds and then fade to the front channel.
    Maybe it is the ota signal and the t.v. is just repeating what it heard.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • dudeinaroom
    dudeinaroom Posts: 3,609
    I could also be signal strength when I was forced to just over air broadcast I used to have the same problem. Got a signal amp and the problem went away as well as the slight gosting, and line in the picture were gone, just my 2 cents worth
