Craigslist does have it all
masanz1
Matthew
Sometimes the road less traveled is less traveled for a reason
HT
Yamaha RX-V2500
CS400-Center
SDA 1A-Mains
RT20-Surround
None right now-Rears
SVS 20-39PCi
Infocus IN72
HT
Yamaha RX-V2500
CS400-Center
SDA 1A-Mains
RT20-Surround
SVS 20-39PCi
Infocus IN72
SIGMOIDOSCOPE...My hunt is over.
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
2 questions.
1) How does someone come to own one of these?
2) Why would someone ever want to buy one for, lets assume, their home?
I pray they are selling this on behalf of some poorly run hospital or clinic. -
Can I just ask... am I supposed to know what that is?If you will it, dude, it is no dream.
It is the medical communities instrument version of Broke Back Mountain for medical purposes to look for polyps/tumors. If found, they are removed & hopefully you won't die of cancer.
"Sigmoidoscopy (sig-MOY-DAHS-kuh-pee) Inspection of the lower colon using a thin, lighted tube called a sigmoidoscope. Samples of tissue or cells may be collected for examination under a microscope. Also called proctosigmoidoscopy."
It's done on both men & women. Sometimes the tumors are so buried, they can't be found.
I should know, my father died of cancer, if they had found were it was buried in his intestines he might have survived. By the time they did, it had spread to his liver & it was too late by then!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I'm pretty sure doro has one of those...More later,
Tour...
Vox Copuli
Don't laugh but....
My company just bought one of these off of E-bay about a year ago. We do engineering (M/E/P) work. As sick as it may sound they are quite handy for looking in "tight" spaces, i.e wall cavities, inside ducts, etc.. With out knowning what it did in its former life you probably wouldn't guess that one even is just by looking at it. It is kind of a wierd thing to sell though.
Yes, it was cleaned up very well before the sale,
No, it doesn't smell,
No, you can't borrow it.Proud SOPA Member since 2005! -
But in industry they're called boroscopes.More later,
Tour...
Vox Copuli
