One More Question Re: PSW450
tkaminski
OK,
First off, thanks to the guys that helped me with the last problem...
Here is my question:
I have the PSW450 Sub...It has both L/R RCA and LFE inputs on it...My Amp only has L/R sub out...There is no LFE out on the amp...Can I still use the LFE in on the sub connecting it to one of the L/R RCA on the Amp or what? I read the manuals on both but they are bit confusing...Any help would be great...Thanks...
Post edited by tkaminski on
read this
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=5076
same answer use the lfe and a single cableDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
So basically use the LFE in on the SUB and does it matter of I use the L or R on the Amp...I am guessing not but just want to make sure...Also I have my fronts set to large (RM6600) and the rest to small...So recom. setting them all to small??? as stated in the link...I have to be honest, the crossover thing really conf. me...I am not real good with the details of HT...The basics I get...Thanks for the help...
I would set all speakers to small, hook up the subwoofer (LFE) "out" of the receiver to LFE "in" at the subwoofer.
Dial the subwoofers variable crossover to the highest setting.
BINGO you are ready.Dodd - Battery Preamp
The thing is my Amp does not have an LFE Out, only Sub put L/R...Should I just use one of those? And if so does it matter which one...Thanks for the reply...Tom
hoosier.....I don't think his "amp" or receiver has an LFE out? I think he is saying there are 2 pre-outs for the sub L/R. tkaminski.....what "amp" or receiver do you have? There is one sure way for you to hook this up and know that it is right....
Run speaker wire from the "amp" or receivers (l/r front speaker terminals) to the sub and from the sub to the l/r front speakers. Run speaker wire to the center and rear speakers from the receiver and set all speakers to SMALL. Set the sub crossover at 150 and you are ready to go.......Oh, the bottle has been to me, my closes friend, my worse enemy! -
Wire the fronts through the sub, and set all speakers to small?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Yep.....Set the sub crossover at 150 and you are ready to go.......:DOh, the bottle has been to me, my closes friend, my worse enemy! -
So, send nothing under 80Hz or so to ANY speaker, including the sub? Should the mains not be 'large'?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Anything under 150 will go to sub with the crossover set there....Those little RM6600's will not play under 150. I think that would be right?Oh, the bottle has been to me, my closes friend, my worse enemy!
The Amp is a Sony 444ES...At this point I have all of the speakers wired directly to the sub...This is how I would like to leave it if poss. and tweak the settings around that...But you are correct, I do not have a LFE out on the AMP...Thanks...Tom
With the mains set to small?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
At thipoint my mains are set to Large and the others are set to small...
OK.....I see what your saying now. Yeap.....fronts set to large is correct to get the sub the full signal. Hell....I drank 12 Millers and 1/2 bottle of 7 last night and my brain is running in "protection mode":DOh, the bottle has been to me, my closes friend, my worse enemy!
Good to see the brain is still running...
Thanks...Now should the Amp be connected via the L or R out on the Amp subout? Thanks... -
This is not the first time I have seen reference to the lower limit of the RM6600 satellite response that has me confused.
My setup is as follows:
Denon 2802,
RM6600, Center and Satellites
Velodyne 12 Sub,
All Satellites connected to speaker out on amp and set to small
Sub connected to sub out on amp
crossover on amp set to 100HZ.
Using a tone generator I am getting a tone from the Satellites as low as 100 Hz. Why is it said that the RM6600 satellites do not play under 150 HZ.
Please, can someone can clear up my confusion? The Velodyne sub only goes as high as 120Hz and I always wonder if I will have a "hole" in my system between 120hz and 150 hz.
freid -
I could be wrong, but I think I have read where Kenneth Swauger has said there lower limit is 150Hz.....Oh, the bottle has been to me, my closes friend, my worse enemy!
Maybe the 100Hz tone is 3-6db down or some such?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Welcome to the forum.
There's 2 ways to do it. I prefer the first for your system.
Run speaker wire to the sub then to the mains. Set your mains to 'large' and you 'sub on/off' on your receiver to 'off'. Use the thickest cable possible between the amp and sub. If you don't have thick quality cable, double it up of equal lengths.
Or:
Hook the sub to both L&R out on your rcvr using a Y-cable if necessary. Set your mains to small.
Freid the same goes for you. Your sats may be able to make those sounds, but out of spec. Is it as loud @100hz as @150hz? The Velo probably plays higher than 120hz, but again out of spec. You might not get a hole, just a dip.
Good luck guys!Make it Funky! -
I had a sony 444es, and still have psw450 subs.
Both sub outs on the Sony are mono.
Connect the sub to either one, all the same.
Use the lfe imput on the sub.
You could even add a second psw450, (I did) front and rear, and the sound was better still.
-Luc
