New Sub Pics
Those are just SUGGESTED retail prices. The price in the store will still be $750.polkaudio sound quality competitor since 2005
SCREW YOU GUYS!
I guessed $499 and Thom said "much less" -- but MSRP is $425 ... Dammit I was close... I'm giving myself a cookie...
*cartman voice* "screw you guys".The Artist formerly known as PoweredByDodge -
The SR6500 has been at MSRP of $899 from the start. Tweeter sells it for $749. If the SR124's MSRP is $425, it will most likely sell for $375- $400. And the SR104 is a bit cheaper.
Thom wrote:If the SR124's MSRP is $425, it will most likely sell for $375- $400. And the SR104 is a bit cheaper.
Ahh... well that's cool. That's right around where the 1st Generation Momo was at when it came out. Sounds fair to me
I suppose I'm going to have to wait and just get these subs. Any clues on what the power handing is going to be on these?-Joe
Rogue Torino wrote:I suppose I'm going to have to wait and just get these subs. Any clues on what the power handing is going to be on these?
I was curious about that too. If I had to guess Id say 500'ish?polkaudio sound quality competitor since 2005
I think 6 or 700 watts RMS.
Definitely! Im gonna have to get a bigger amp now!
What are you planning on getting
? Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
I will have one, or two...
1996blackmax wrote:What are you planning on getting
Crossfire 600D! "600" watts at 1 ohm.polkaudio sound quality competitor since 2005
ew.
Mac... the Crossfire VR602 is the same size...
same power
50% higher damping factor over the 600D
11% higher signal to noise ratio over the 600D
probably the same price.
does its power at 4 ohms bridged... so i'm sure you can swing a singel 4 ohm or dual 2 ohm coil polk SR sub.
it's not like you're lookin for a 1500 - 2500 watt amp, in which case a class D will be about half to 1/3 of the price... possibly be a bit smaller... and the heat loss due to inefficiency would put a big weight on your power ssytem as well as just plain build up heat.... with only 600w i feel you can go class AB from the same manufacturer, get the same power with better characteristics, and be happier.The Artist formerly known as PoweredByDodge -
Well, that damping factor difference will be inaudible as will the signal to noise difference. Plus, Crossfire's Class D amps are not only insanely powerful but effecient as well. CA&E tested one recently and it made 767x1 at 1 ohm, .1% THD at 79% (!) effeciency!
Now dont get me wrong, Im a big fan of their stereo amps as well as I have their VR302 running my beloved MM2104 right now but their Class D amps are made to pound their guts out and never so much as whimper.
Also a nice little bonus is the 600D is about half the size of the 602.polkaudio sound quality competitor since 2005
