denon 3805 and multi room connections
moraks
moraks Posts: 49
i have a 3805 that I will be using in a 5.1 setup, i want to use the rear surround for multi zone setup with one rc6s speaker in the bedroom and one in the bathroom with the denon as the source for the sound in both rooms. My assumption is that I am limited to one speaker in each room, which is on eof the reasons that I am going with the rc6s, am I correct?
Post edited by moraks on
  • bassaholic
    bassaholic Posts: 315
    edited February 2006
    yep youre correct.
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
    SVS PB13 Ultra & PSW650
    Monster Power 3250 amp
    Monster Power 2250 amp
    Monster Power HDP-2500 surge pro.
    Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust
  • mantis
    mantis Posts: 17,629
    bassaholic wrote:
    yep youre correct.
    No your not. The rc6 is a stereo output speaker which requires both left and right from the surroundback/zone 2 amp outputs. What you need is a speaker selector box then you can run both of the stereo speakers in the bedroom and bath. If the masterbed can benefit from a stereo pair, I suggest you go that route and use the RC6 stereo speaker in the bathroom. But first you must get a speaker selector box.
    Dan
    Dan
  • moraks
    moraks Posts: 49
    thanks, mantis.
    u are correct, i called denon today and he gave me the same advice, i will be getting a speaker slector box that can handle 4 speakers and i intend on getting the rc60i pair for the bedroom and the rc6s for the bathroom . i am leaning towards the VSS2 2 Pair Speaker Selector Dual Source Volume Control
    any comments or do you have a recommendation
  • RoosterD
    RoosterD Posts: 36
    deleted...
    Denon 3805S
    Denon 3910S
    Polk LSi 15's
    Polk LSi F/X's
    Polk LSi C
    Boston Pro 10" DIY Sub
    Samsung 5678W DLP 1080P
    PS3
