need help on modifications for tweeter change
amertalk
amertalk Posts: 6
edited February 2006 in Forum Testing Area
Hi.....i ordered 4 new silk dome polk replacements for my sda 2s..i will have to enlarge the holes as this has sl1000 l/p tweeters. how did you do it..what was easiest approach? what tools? Thanks! :rolleyes:
Post edited by amertalk on
  • dorokusai
    dorokusai Posts: 25,638
    edited January 2006
    I think the only person that has actually performed this, to my knowledge, is Aardvark.
    It's basically a router operation...if you're comfortable with that tool, you're golden.
  • BobMcG
    BobMcG Posts: 1,585
    edited January 2006
    He's not really going to try it. It's just a test. :p
  • amertalk
    amertalk Posts: 6
    edited January 2006
    i will be trying it this weekend with the help of a friend.....was hoping someone else has tried this....thanks for any help
  • amertalk
    amertalk Posts: 6
    edited January 2006
    has anyone tried just replacing the main tweeter in each cabinet..leaving the sda tweeter alone.....so keeping two sl1000 or 2000 tweeters and going silk dome on the others. I am a serious lover of polk sda's. This is one of two pairs i own. i also own the sda crs+ model...my favorite so far. I have had the pleasure of interviewing Mathew Polk on my radio show last year...but I had not tried the sda's at that time. I would have had many other questions for him!
  • genem
    genem Posts: 1
    This process can be done with either a router or a jig saw. Make you a template out of paper, the diameter of the driver , minus the flange.
    Trace it on to your baffle. If you cut to the inside of the line, even if you use a jig saw , nobody will know the difference but you.
    Hope that helps
