Early B BBB Brad oh dude...
VR3
Dude..
How many coats of clear did you put on your sub?
Because Im on my 2nd coat, I plan to put four...
Dude each coat looks better...and better. Wow, so purdy!
Cant wait till I get these things cleared...
Looks like it will take a week or two (or three) lol...
Do you got any pics of your sub with the clear?
Post edited by VR3 on
I put on only two coats. Too lazy to put more coats on. Now that you mention it, since my Atlas 15" has been sent to the shop, now's a good time to put a couple more coats on.
I used semi-gloss because I don't want it too shiny that it'll stand out in the room. Got it mostly hidden from view anyway.
BTW, I just finished adding two coats of poly on my Titanic sub. Looked dull and lifeless before, but now it is showroom worthy. Makes a huge difference even though this sub will be totally hidden.
No pics, but it looks nice. Thanks for the poly over bed liner idea.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Just added the third coat. Will add the fourth and final coat this evening.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Make sure to wear the proper breathing gear, that crap is bad for you.
Awesome Early...
It looks so much better dont it? I also like the fact it seals the finish, since that "grit" on the truck bed liner kind of flakes off at times...
I really like the way it looks...and that cedar is PURDY.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
5th coat!!!
ONE MORE TO GO...
Ive almost used an entire quart of clear... (on one speaker)
I can see myself... in the side panel.
I stopped with an extra thick 5th coat. That's when I ran out of poly. That stuff has a potent odor to it. Can't drag the box back into the house until the smell goes away.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
It does man... lol
Im thinking of investing in a bottle of febreeze...
Im done clearing the entire enclosure, I am just applying coats to the end grain of the cedar on one side as it is soaking the crap out of this clear, but it is slowly taking it in.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
