New Alpine h/u's and Best Buy
  • rodney
    rodney Posts: 91
    edited January 2006
    Eclipse units use true 24bit Burr Browns :D.
    http://www.kenwoodusa.com/products/Feature.asp?sif=467
    alpine cda-9857
    polk db6500
    polk ex369
    polk/momo mm104
    profile ap1040
    kenwood kac-7251
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2006
    neomagus00 wrote:
    hear, hear!
    and while we're on TA, does anyone know of an external TA unit that can independantly do at least 4 channels, preferably six? all i need is time alignment, nothing else, cause the TA feature on pioneers is crappy, and i'd like to try it...
    I wondered this too. It would be great if I could just buy an external processer that does TA so I could keep my current head unit.
  • exalted512
    exalted512 Posts: 10,734
    edited January 2006
    the good one will run $700 msrp. 6 band eq? Try 31 band on EACH front speaker and 28 on EACH rear speaker. 10 band eq on the sub. Adjustable slopes, fully adjustable subsonic filter (Each frequency).
    -Cody
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited January 2006
    rodney wrote:
    Not worky worky :( .
    I know what you are saying though ;)
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • neomagus00
    neomagus00 Posts: 3,899
    edited January 2006
    -Cody
    yeah, i meant 6-channel, duh me...
    what's the difference between the good one and the other one(s)? and can i score a hyperlink?
  • exalted512
    edited January 2006
    not totally sure, our fosgate rep just had the 700 dollar one...hyperlink? try the "rockford fosgate 360º" thread
    -Cody
  • MacLeod
    edited January 2006
    Id forgotten about Rockford Fosgate making head units. Ill look into those. So far tho its looking like Eclipse is going to be hard to beat.
    *edit
    Well maybe they dont. Just checked their website and they dont have head units listed at all. Did they quit making them?
  • MacLeod
    edited January 2006
    Hey! JVC makes a good one. 5 volt pre-outs, variable time alignment, 9 band EQ. $430 shipped from Sounddomain!
  • exalted512
    edited January 2006
    fosgate no longer makes radios...actually they never really made radios. They just stamped their name on some.
    -Cody
  • brettw22
    brettw22 Posts: 7,623
    edited January 2006
    I like the look of that one, but the screen could be bigger..........
    I'd like to see more screen and fewer space taken up by buttons that are so multi function that you don't dare try to change **** while you're driving down the road........
  • Greg Peters
    Greg Peters Posts: 605
    edited January 2006
    Backing up to the Alpine 9855 (2005 model), it is not that bad of a h/u really. While it is nowhere near as adjustable "on the fly" as previous models (or current models without the "glide touch strip"), you can get very good SQ out of one of these.
    I have played with them on the sound board in the Alpine dealer, and my brother bought one as an upgrade to a top of the line Clarion he was running. It did make a drastic improvement over the Clarion once it was properly dialled in. The 9855 gives you the option of Alpine's standard 5 band parametric EQ (or a 7 band graphic EQ if you prefer). There is plenty more control in the 9855 over a model with basic Bass/Treble adjustment controls, and that is part of the problem. It is not for beginners.
    The 9855 has garnered it's share of hateful reviews on Crutchfield, and most are based on the "glide touch" control. There are people in the same reviews who swear by the sound quality they get from it though. The majority of settings done with the glide touch are not something you would be tempted to play with while sitting at a red light anyway. It is a complicated h/u, but fairly intuitive if you have any experience in how to properly tune a system. The graphics it uses to display crossover settings and corresponding slopes do make it very understandable when setting up these functions. The 9855 offers those who want the ability to adjust almost everything the ability to do so from the dash.
    I have one "new in the box", bought for another install I will be doing. Based on SQ alone, I would be tempted to buy another for myself (if the price were right). After getting a chance to hear what this h/u was capable of with some careful tweaking (especially after seeing the spec's and lower voltage pre-outs on the majority of 2006 models) a 9855 is starting to look better than at first glance. Clearance pricing should make them look even better. Where Alpine failed with the 9985 is that many people who could afford to buy it had no clue as to how to use one once it was installed. Some high-end Pioneer units have the same problem.
    Anyone dropping $1600 of their coin for Alpine's 2006 top of the line DVA-9965 h/u will get that same "glide touch" control.
  • MacLeod
    edited January 2006
    Yeah, it looks like Ill be turning my back on Alpine now. Elclipse is a strong option but they recently announced they wont be supporting the competition sactioning orgs anymore so they drop down my list also.
    Those new Nak's look really cool. I have to admit it would be damn cool to have one of those!
  • 1996blackmax
    edited January 2006
    I have been reading about reliability issues with Nak's.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • neomagus00
    edited January 2006
    crikey, is there any brand left that doesn't have quality OR style issues?
  • cam5860
    cam5860 Posts: 632
    edited January 2006
    I read a lot of reviews also that said that the alpine 05 models sound a good bit better than the 04 models did. That being the 9855 compared to the 9835.
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited January 2006
    Kenferd seems allright :)
    The Artist formerly known as PoweredByDodge
  • MacLeod
    edited January 2006
    There wont be an audible difference between the 05 and 04 models unless youre talking about different EQ and tuning features. Other than that, theyll sound the same.
  • cam5860
    cam5860 Posts: 632
    edited January 2006
    Yeah thats what I was refering to better EQ and so forth.
  • hrdhtdvr
    hrdhtdvr Posts: 103
    edited January 2006
    I have to agree. The glide touch thing is pretty much crap. Try to use it to look for a specific song on a cd. Unless you are stopped, it is pretty frustrating. But then again, I do live in Louisiana and they must have some of the worst roads in America
    Alpine 9855 hu
    Polk/Momo MMC 460 (Rear)
    Polk/Momo MMC 6500 (Front)
    Polk/Momo MM 2104 Sub
    Amp: JL 500/5
    Wires: Street Wires
    Sat Radio: Sirius PNP
    ______________________
    Home
    Kenwood CD 425M 200 disc cd changer
    Denon AVR-2801 reciever
    Mitsubishi HS-U577
    Toshiba -SD1700 DVD player
    Klipsch Speakers
    Center: RC-7
    L&R:KLF-20
    Surrounds:RS-3
    Sub: KSW-15
