Hookup of older CD player to Denon 3805
donahue
donahue Posts: 125
I just purchased the Denon 3805 and have a question about hooking up an older CD player. I have an older (much) Sony ES 5-disc CD player that has both analog and optical outputs. I am assuming that if I use the analog outputs, the CD player does the digital->analog conversion, whereas if I use the optical output, the receiver will be doing the digital->analog conversion. First, is this assumption correct? Secondly, what would be the recommendation for hookup?
Thanks,
Ray
Post edited by donahue on
  • cnjvh
    cnjvh Posts: 253
    edited January 2006
    Your assumption is correct. Your Denon has a very nice array of Burr Brown DAC's. Try it both ways, but I can all but guarantee that using the optical out and letting your receiver do the DAC will be the way to go.
    No earth robot is going to tell ME which button to press!!
    --Stuff--
    Front: Polk Audio RTi12
    Center: Polk Audio CSi5
    Surrounds: Polk Audio RTi8 (x4)
    Sub: SVS PB10-ISD (Dual)
    AVR: Denon AVR-3805
    Blu-Ray: Panasonic BD30
    Display: Sony KDL-55NX720B
    STB: Xfinity X1DVR
