10" or 12" subwoofer
Great writeup! The original titanic 12" was always noted as very musical while not that great for HT. It has not been available for quite some time though.
I hooked up the sub to my HT system just to see how it sounds there even though the room is too large for it. Sounded pretty decent, but the driver was working real hard to keep up. I feared for it and turned the volume down before the poor thing exploded. While I believe in a smaller room it would do well, I would still recommend a ported sub. There are a couple of excellent options in its price range such as the Hsu STF-2 and SVS PB10.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Back to the stereo sub idea -- I was interested in this concept so I rolled my HT sub into the living room where my 2-channel system is located for a demonstration of the stereo sub concept and connected an RCA cable to the extra "white" inputs on my CD player (other sub was connected to the corresponding "red" inputs).
Results -- I heard absolutely no difference whatsoever. Therefore, I see no reason to pursue the stereo sub thing. I'm not saying it doesn't make a difference, just that in my little experiment I couldn't tell the difference.
I wonder, though, why stereo subs are recommended *if* bass is actually omnidirectional. Doesn't seem like the stereo imaging thing would apply to bass. I'm puzzled. Can anyone help me out on this one?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
You need to find a recording that uses stereo bass. If it's not in the mix, then you won't hear any difference. Bass is far less direction below about 80 hz, but you can still tell where it's comming from. Do you have Beck's latest? I seem to remember it having some interesting bass from each speaker.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
How do you know if a recording uses stereo bass (before you buy it)? How many are out there?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
You don't. I'd bet that some engineers/producers will consistantly record tracks that way, so once you find a few recordings, you could use www.allmusic.com to find other recordings that they've done, but there's no telling.
In my recording experience, usually no one really even thinks about it. You spend forever getting the drums mic'd just right, then spend about 30 seconds setting up the bass, punch it to the L&R busses and that's that.
If I have time this weekend, I'll poke through my vinyl and see if I can find some fairly common recordings that have it. Try Dark Side of the Moon or Wish you were here. I don't know for sure, but I'd put money on them. Also try anything that's been produced by the Dust Brothers.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Thanks, unc. I'm a jazz enthusiast. Just wondering if anyone knows whether or not any jazz recordings are mixed with stereo bass.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Ascendant released their drivers, with some VERY nice intro prices.
http://www.ascendantaudio.com/index.htmSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
