best tower speakers for under 1000$
millerman 3732
millerman 3732 Posts: 1,488
edited January 2006 in Speakers
what are the best tower speakers Polk or not for under a 1000$ .not a lot of retailers around my location, CC and BB is about it so I'll have to shop off the internet and and no way to audition any speakers so i need some help, any thougts or input ?
P.S. I did a search on this topic and didn't get any results so if this is an old topic please forgive me and show me where to find it
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar
  • venomclan
    venomclan Posts: 2,467
    edited January 2006
    check out the ONIX rockets or the Athena towers at audioadvisor.com.
    Venom
  • LuSh
    LuSh Posts: 887
    edited January 2006
    Polk Audio LSI 15's...USED.
  • McLoki
    McLoki Posts: 5,231
    edited January 2006
    That would be my vote as well. (although SDA 1b's with upgraded tweets are pretty awesome as well.)
    The 15's had my vote, thats why I purchased them (for under $1,000).
    If you are open to purchasing used, go out and start listening. There are a ton of speaker brands available, find some you like and then see what you can get.
    Michael
  • Early B.
    Early B. Posts: 7,900
    edited January 2006
    Open ended question. Literally hundreds of options. You'll have to tell us stuff like:
    - if the tower speakers will be used primarily for HT or 2-channel
    - the type of music you listen to
    - WAF considerations
    - new or used
    - accompanying components
    - space constraints
    - room size
    - aesthetic preferences
    - sensitivity, and
    - what you're looking for -- sweet midrange, low bass, wide soundstage, etc.
    "God grooves with tubes."
  • millerman 3732
    edited January 2006
    - new or used
    - space constraints
    - room size
    - sensitivity, and
    O.K. Early B. here goes
    -Mostly HT some music 80% 20%
    -Every thing from George Strait to AC/DC
    -WAF, I don't know what that is , sorry still learning
    -New or used, either is fine as long as used is in good shape
    -Componnents
    - HK AVR 635
    - CS400i (center)
    - RTi6 ( mains right now but to be moved to side surrounds)
    - RTi 4 ( side surrounds to be moved to back surrounds)
    -Klipsch KSW 15 (sub)
    -Space is really not a problem but SDA's might be alittle to big
    -Room size is an L shape 20Lx13w in front 26w in back vaulted ceiling 8' to11'
    -Aesthetics, really would like a taller speaker to blend with hieght of the T.V.
    (around 5'7'') and I'd like them to be black to match the rest of the speakers_
    - Sensitivity, not sure?
    - Looking for something wth good highs but not to harsh good mid down to around 40 htz.
    Also do not want to limit my self to just the RTi line just to match the rest of the speakers ,I'll upgrade the rest later, but if thats the best choice I am willing to go that way, also I will add externals amps later but only if need be
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
  • karpiel666
    karpiel666 Posts: 173
    edited January 2006
    i would go with rt800i a pair can be had for 400+shipping and i think they are amazing for the price.
    dvd player: samsung DVD-HD850
    receiver: Denon avr5700
    center: polk cs400
    fronts: polk rt800i
    surrounds: Unknown Polk monitor? series.
    sub: svs pb12 isd/v
    tv: 46 inch samsung
  • ohskigod
    ohskigod Posts: 6,505
    edited January 2006
    80% movies, I say go new with the RTi8. you wont go wrong with any option mentioned so far though.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Early B.
    edited January 2006
    Thanks for answering the questions. Based on those responses, you've narrowed down your options considerably. I'd suggest the RTi10, possibly with external amplification later on. After the fronts, the sub should be the next upgrade.
    If you get another type of speaker, you'll at least want the matching center channel.
  • millerman 3732
    edited January 2006
    Noted, thanks for the reply :)
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2006
    "-WAF, I don't know what that is , sorry still learning"
    Wife Approval Factor
    WAAAAA!
  • Ricardo
    Ricardo Posts: 10,634
    edited January 2006
    I second the RTi8's, and that leaves you with some extra to put towards the sub....
    SOPA
  • drew spelts
    drew spelts Posts: 310
    edited January 2006
    how about the rti10's thats what i just bought. But I have not heard them yet because they will not be arriving till around monday.
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
  • Ricardo
    edited January 2006
    The RTi10's are great speakers; I just think that if you have a good sub you can save some money and get the 8's with absolutely no loss.
    SOPA
  • BIZILL
    BIZILL Posts: 5,432
    edited January 2006
    word.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Joey_V
    Joey_V Posts: 8,603
    edited January 2006
    LSi15 used.
  • Early B.
    edited January 2006
    Not necessarily. First, Millerman will have the option of running the 10's on LARGE and get a fuller sound with loads of bass. That's what I did when I owned the 10's and I loved it.
    Second, even if he uses a sub and puts the 10's on SMALL, he's gonna get a fuller sound than the 8's can provide, and for HT you really want a full sound.
    Third, Millerman's room size is significant and it could certainly benefit from larger floorstanders.
    Fourth, Millerman has expressed interest in external amplification and once he powers those 10's with an amp, he'll be in sonic heaven.
  • BIZILL
    BIZILL Posts: 5,432
    edited January 2006
    i run my rti8's LARGE.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • millerman 3732
    edited January 2006
    okey guys 8's or 10's and is there a $300 difference in sound
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
  • McLoki
    McLoki Posts: 5,231
    edited January 2006
    I would say yes, because the sound is different in each. (I know some people who like the 8's but hate the sound of the 10's and vice versa)
    I would listen to both and see if you like the sound of one or the other. If the sound is the same either way to you - go with the one you want.
    Michael
  • GATOR3000
    GATOR3000 Posts: 355
    edited January 2006
    Go with the 8's and use the $300.00 against a nice sub. I do agree, the 10's would give you a fuller sound in your room though.
    Listen to both and see if it is worth the $300.00 more.
    Theatre System 5.1
    Sumsung HP-S5053 plasma
    Receiver Denon AVR 3806 Pre/Pro
    Parasound HCA 1500A amp (front L/R)
    Parasound HCA 1000A amp (centre)
    B & K AV5000 amp (bi-amp + surround)
    Dynaco ST70 tube amp (Herbie HAL-O9)
    polkaudio Lsi15 (Cherry) 2-channel
    polkaudio Rti8 Front (Cherry)
    polkaudio Csi5 Centre
    polkaudio Rti6 Surround
    polkaudio PSW1000 Subwoofer (Cherry)
    Original A8T CD
    Pioneer DV-275 DVD Player
    MONSTER CABLE MP-HTS3500MKII Powercentre
  • millerman 3732
    edited January 2006
    I think i'am going to just bite the bullet and try and find some LSI 15's, I'am the type of person who thinks that he can always do better and if I spend a $1000 now on something out of the RTi line I'll always be second guessing my self and still looking to upgrade to some thing better so i might as well speand the money now on some 15's rather than speand the money on some RTI 10's and in a year be wondering if i could have done better and be stuck with a set of speakers i 'am not happy with or THINK I'am not happy with that is
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
  • cfrizz
    edited January 2006
    Sounds like a smart plan Millerman!
  • krabby5
    krabby5 Posts: 923
    edited January 2006
    Isn't he using the CS400i for his center channel? If that is the case, shouldn't he be trying to find the older RTxxxxi line so his fronts match?
    Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
  • amulford
    amulford Posts: 5,020
    edited January 2006
    I would...
  • millerman 3732
    edited January 2006
    A friend of mine here on the forum Is hooking me up with a set of RTI10's at a good price so I'am going to go that way and see what happens and I'll upgrade the center to a CSi 5 in a couple of months I really wanted to go LSi but money and space for amps is kinda tight right now and alot of the folks here talk very highly of the 10's so I'am sure I won't be dissapointed, later
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
  • gregure
    gregure Posts: 871
    edited January 2006
    I'm sure you'll find the 10's to be more than satisfactory. I'm quite happy with them, even after 3 years. If you only listen to music 20% of the time, honestly, you've no need to go LSi. The Rti are great speakers for movies, and only someone who really sits and listens to music for the sheer pleasure, relishing the openness of sound and level of detail need take the plunge into the LSi territory. Then, you're really not hearing them properly w/o a good amp, so it sounds like the 10's are a perfect match for you. As music speakers they are still very good, if not quite as smooth in the highs and detailed as Lsi. Plus, the 10's will sound pretty good on your receiver, and you could move up to a better amp for the 10's for music playback later on. Two Outlaw monoblocks can be had for under $700. That's a pretty good deal. That will be like a speaker upgrade in and of itself.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
