best tower speakers for under 1000$
millerman 3732
what are the best tower speakers Polk or not for under a 1000$ .not a lot of retailers around my location, CC and BB is about it so I'll have to shop off the internet and and no way to audition any speakers so i need some help, any thougts or input ?
P.S. I did a search on this topic and didn't get any results so if this is an old topic please forgive me and show me where to find it
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Post edited by millerman 3732 on
check out the ONIX rockets or the Athena towers at audioadvisor.com.
Venom -
Polk Audio LSI 15's...USED.
That would be my vote as well. (although SDA 1b's with upgraded tweets are pretty awesome as well.)LuSh wrote:Polk Audio LSI 15's...USED.
The 15's had my vote, thats why I purchased them (for under $1,000).
If you are open to purchasing used, go out and start listening. There are a ton of speaker brands available, find some you like and then see what you can get.
Open ended question. Literally hundreds of options. You'll have to tell us stuff like:
- if the tower speakers will be used primarily for HT or 2-channel
- the type of music you listen to
- WAF considerations
- new or used
- accompanying components
- space constraints
- room size
- aesthetic preferences
- sensitivity, and
- what you're looking for -- sweet midrange, low bass, wide soundstage, etc.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
O.K. Early B. here goesEarly B. wrote:Open ended question. Literally hundreds of options. You'll have to tell us stuff like:
- new or used
- space constraints
- room size
- sensitivity, and
-Mostly HT some music 80% 20%
-Every thing from George Strait to AC/DC
-WAF, I don't know what that is , sorry still learning
-New or used, either is fine as long as used is in good shape
-Componnents
- HK AVR 635
- CS400i (center)
- RTi6 ( mains right now but to be moved to side surrounds)
- RTi 4 ( side surrounds to be moved to back surrounds)
-Klipsch KSW 15 (sub)
-Space is really not a problem but SDA's might be alittle to big
-Room size is an L shape 20Lx13w in front 26w in back vaulted ceiling 8' to11'
-Aesthetics, really would like a taller speaker to blend with hieght of the T.V.
(around 5'7'') and I'd like them to be black to match the rest of the speakers_
- Sensitivity, not sure?
- Looking for something wth good highs but not to harsh good mid down to around 40 htz.
Also do not want to limit my self to just the RTi line just to match the rest of the speakers ,I'll upgrade the rest later, but if thats the best choice I am willing to go that way, also I will add externals amps later but only if need beCasey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Polk Signa-1 Surround bar -
i would go with rt800i a pair can be had for 400+shipping and i think they are amazing for the price.dvd player: samsung DVD-HD850
receiver: Denon avr5700
center: polk cs400
fronts: polk rt800i
surrounds: Unknown Polk monitor? series.
sub: svs pb12 isd/v
tv: 46 inch samsung -
80% movies, I say go new with the RTi8. you wont go wrong with any option mentioned so far though.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Thanks for answering the questions. Based on those responses, you've narrowed down your options considerably. I'd suggest the RTi10, possibly with external amplification later on. After the fronts, the sub should be the next upgrade.
If you get another type of speaker, you'll at least want the matching center channel.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Noted, thanks for the replyEarly B. wrote:Thanks for answering the questions. Based on those responses, you've narrowed down your options considerably. I'd suggest the RTi10, possibly with external amplification later on. After the fronts, the sub should be the next upgrade.
Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
"-WAF, I don't know what that is , sorry still learning"
Wife Approval Factor
WAAAAA!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I second the RTi8's, and that leaves you with some extra to put towards the sub...._________________________________________________
how about the rti10's thats what i just bought. But I have not heard them yet because they will not be arriving till around monday.Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes: -
The RTi10's are great speakers; I just think that if you have a good sub you can save some money and get the 8's with absolutely no loss._________________________________________________
word.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
LSi15 used.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
HTrookie wrote:The RTi10's are great speakers; I just think that if you have a good sub you can save some money and get the 8's with absolutely no loss.
Not necessarily. First, Millerman will have the option of running the 10's on LARGE and get a fuller sound with loads of bass. That's what I did when I owned the 10's and I loved it.
Second, even if he uses a sub and puts the 10's on SMALL, he's gonna get a fuller sound than the 8's can provide, and for HT you really want a full sound.
Third, Millerman's room size is significant and it could certainly benefit from larger floorstanders.
Fourth, Millerman has expressed interest in external amplification and once he powers those 10's with an amp, he'll be in sonic heaven.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
i run my rti8's LARGE.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
okey guys 8's or 10's and is there a $300 difference in soundCasey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
I would say yes, because the sound is different in each. (I know some people who like the 8's but hate the sound of the 10's and vice versa)millerman 3732 wrote:okey guys 8's or 10's and is there a $300 difference in sound
I would listen to both and see if you like the sound of one or the other. If the sound is the same either way to you - go with the one you want.
Go with the 8's and use the $300.00 against a nice sub. I do agree, the 10's would give you a fuller sound in your room though.
Listen to both and see if it is worth the $300.00 more.Theatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre -
I think i'am going to just bite the bullet and try and find some LSI 15's, I'am the type of person who thinks that he can always do better and if I spend a $1000 now on something out of the RTi line I'll always be second guessing my self and still looking to upgrade to some thing better so i might as well speand the money now on some 15's rather than speand the money on some RTI 10's and in a year be wondering if i could have done better and be stuck with a set of speakers i 'am not happy with or THINK I'am not happy with that isCasey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Sounds like a smart plan Millerman!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Isn't he using the CS400i for his center channel? If that is the case, shouldn't he be trying to find the older RTxxxxi line so his fronts match?Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
krabby5 wrote:Isn't he using the CS400i for his center channel? If that is the case, shouldn't he be trying to find the older RTxxxxi line so his fronts match?
I would... -
A friend of mine here on the forum Is hooking me up with a set of RTI10's at a good price so I'am going to go that way and see what happens and I'll upgrade the center to a CSi 5 in a couple of months I really wanted to go LSi but money and space for amps is kinda tight right now and alot of the folks here talk very highly of the 10's so I'am sure I won't be dissapointed, laterCasey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
I'm sure you'll find the 10's to be more than satisfactory. I'm quite happy with them, even after 3 years. If you only listen to music 20% of the time, honestly, you've no need to go LSi. The Rti are great speakers for movies, and only someone who really sits and listens to music for the sheer pleasure, relishing the openness of sound and level of detail need take the plunge into the LSi territory. Then, you're really not hearing them properly w/o a good amp, so it sounds like the 10's are a perfect match for you. As music speakers they are still very good, if not quite as smooth in the highs and detailed as Lsi. Plus, the 10's will sound pretty good on your receiver, and you could move up to a better amp for the 10's for music playback later on. Two Outlaw monoblocks can be had for under $700. That's a pretty good deal. That will be like a speaker upgrade in and of itself.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner
