what sounds better, in ceiling speaker or bookshelf surround speaker
drew spelts
drew spelts Posts: 310
edited January 2006 in Speakers
question is, what will sound better. An in ceiling speaker that basically has no box or a bookshelf "type" surround speaker. These will be used as rear surrounds mounted to a cathedral type ceiling. Since they will be on a cathedral type ceiling they will be abgled down twards the viewing area at 30-40 degrees I would guess. They will be about 2 feet behind the listening plane. let me know your thoughts.
Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes:
Post edited by drew spelts on
  • hoosier21
    hoosier21 Posts: 4,420
    edited January 2006
    in ceiling would look better, for rears set to small, I would think the sound would be as good as a bookshelf speaker
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • mantis
    mantis Posts: 17,559
    edited January 2006
    I agree somewhat. Sometimes the inceilings sound a bit better due to better placement in the room.I really loe inceiling rear speakers as you have total control over placement. Inceiling speakers sound great.
    Dan
    Dan
  • Skynut
    Skynut Posts: 2,967
    edited January 2006
    I do not like the idea of inwall or inceiling speakers. I don't like the lack of mobility.
    I have heard them sound prety good for mood music or whole house music but I have never heard any I thought would sound good in my particular application.
    Free standing speakers are easier to tweek or switch out whenever you want to.
    Of coarse who switches out their surrounds very often?
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Taurus574
    Taurus574 Posts: 52
    edited January 2006
    I thnk "bookshelf" speakers on adjustable mounts is better. If it was up to me I'd have it that way since I can angle it the way I want it to sound best. Plus it is in an enclosure that will provide the best acoustic sounds. In-wall mounted speakers are pretty sweet looking tho, cleanest install. For HT, my opinion would be "bookshelf."
    Yamaha HTR-5490, Polk RT1000I, cs4000i, CS175 and R10 .... and a soon to be SVS 20-39 PCI
