output impedance of dodd elp
marvda1
before i try to contact gary, does anyone know the output impedance of the dodd elp?
marvin
marvin
Puritan PSM156
Puritan PSM156
Post edited by marvda1 on
<200ohm.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
would a solid state amp with an input impedance of 47 kohms have a problem mating with the dodd elp at the <200 ohm output impedance?
and does the fact that the amp has a sensitivity of 0.9 v matter?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I think Gary said 100 when I spoke to him, but I have no idea how to answer your question..
SorryCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
The input is much higher then the output impedance, so no problem hooking that up.
Are you have a problem with that setup?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
yes i am having a slight hum problem. can only hear it when i am up to change cd's. it was much louder( could hear it 7 ft, away) before it took it to gary and he outboarded the transformer and put a choke in the preamp.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Does the amp have a 3 prong plug? If so this could be causing the problem, not sure just something I read on this forum....
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
it's not the plug, i tried a cheater plug and also a replacement cord that only had two prongs.
marvinAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Sorry I'm at a loss.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Any video sources hooked up?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
nopeAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
someone brought the dodd 120 watt mono's by, the's having a hum problem. they also hummed at my place.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Did you try changing IC's ?JC approves....he told me so. (F-1 nut)
the amps were with different interconnects and in a different system and home. i have the hum in my preamp even with no interconnects connected. it does go away when i engage the preamp's mute switch.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Oh just call Dodd, you guys and your humming.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
a least it's musical! mine is not a problem as i can only hear it when i am up to change cd's. the sound of the preamp more than makes up for it.
Puritan PSM156
