output impedance of dodd elp
marvda1
marvda1 Posts: 4,952
edited January 2006 in 2 Channel Audio
before i try to contact gary, does anyone know the output impedance of the dodd elp?
marvin
Puritan PSM156
Post edited by marvda1 on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2006
    <200ohm.
  • marvda1
    edited January 2006
    would a solid state amp with an input impedance of 47 kohms have a problem mating with the dodd elp at the <200 ohm output impedance?
    and does the fact that the amp has a sensitivity of 0.9 v matter?
    Puritan PSM156
  • beardog03
    beardog03 Posts: 5,550
    edited January 2006
    I think Gary said 100 when I spoke to him, but I have no idea how to answer your question..
    Sorry
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2006
    The input is much higher then the output impedance, so no problem hooking that up.
    Are you have a problem with that setup?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • marvda1
    edited January 2006
    yes i am having a slight hum problem. can only hear it when i am up to change cd's. it was much louder( could hear it 7 ft, away) before it took it to gary and he outboarded the transformer and put a choke in the preamp.
    Puritan PSM156
  • disneyjoe7
    edited January 2006
    Does the amp have a 3 prong plug? If so this could be causing the problem, not sure just something I read on this forum....
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • marvda1
    edited January 2006
    it's not the plug, i tried a cheater plug and also a replacement cord that only had two prongs.
    marvin
    Puritan PSM156
  • disneyjoe7
    edited January 2006
    Sorry I'm at a loss.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • RuSsMaN
    edited January 2006
    Any video sources hooked up?
  • marvda1
    edited January 2006
    nope
    Puritan PSM156
  • marvda1
    edited January 2006
    someone brought the dodd 120 watt mono's by, the's having a hum problem. they also hummed at my place.
    Puritan PSM156
  • george daniel
    george daniel Posts: 12,096
    edited January 2006
    Did you try changing IC's ?
  • marvda1
    edited January 2006
    the amps were with different interconnects and in a different system and home. i have the hum in my preamp even with no interconnects connected. it does go away when i engage the preamp's mute switch.
    Puritan PSM156
  • RuSsMaN
    edited January 2006
    Oh just call Dodd, you guys and your humming.
  • marvda1
    edited January 2006
    a least it's musical! mine is not a problem as i can only hear it when i am up to change cd's. the sound of the preamp more than makes up for it.
    marvin
    Puritan PSM156
