LSi15 and Rotel RB-1080
I am thinking of upgrading my speakers from RTi100s to LSi15s. I have a Rotel RB-1080 amp (rated 200 wpc @ 8 ohm) that will be used to drive the LSi15s. Is this a good combination or are there any preferred amps for the LSis?
Post edited by dinnu on
The rb1080 has plenty of power to drive the Lsi15's and behond. Good luck with your upgrade. It's a good one.
DanDan
OH YEAH!!! That is a very good combination!!! Enjoy!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Sounds good to me. The RTI100s are what I upgraded from. You will like the difference.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Same as above....good match...System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
Thank you for the encouragement. How much should I expect to pay for a pair of used LSi15s?
I have one more question, I have a Rotel RB-980BX (rated 120 w/ch @ 8 ohm). Can I use this along with my RB-1080 to bi-amp the speakers? I was thinking of powering the tweeters with the 980 and the drivers/woofers with the 1080.
Thanks in advance. -
anyone?
Used 15's range from $850-$1100. As far as biamping, it will work, but you might not be gaining monumental improvements. You can always try it and post back here.
ZachTschüss
Zach -
There's a "mint condition" pair on Ebay right now. Check it out here.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
You'd probably not want to bi-amp.. rather, sell both amps and get an RB1090 if you want supreme Rotel sound. If not, then just keep the powerful 1080 and sell the 980.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Thanks for the suggestions.
I will probably have to pass on the cherry pair as I am looking for a black pair (Wife's Advice
As for selling the amps, I will wait till I get the LSis and then think about it. I actually have 2 RB-1080s. One of them is at Rotel right now for the fix for fuse blowing issue.
I had an opportunity to compare the LSis and the RTis at a local FRY's store. I will post my observations in another thread. -
I imagine the Lsi's sound good for HT. I have the RTi100's with a Rotel 1080 and I think the HT component sounds very good. Music on the other hand could stand some improvement. Good Luck.Michael
NORTH of 60° -
Geez... that's a lot of rotels. Awesome~Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
