how do you know how low the sub is digging
drew spelts
I am building a hopefully awsome sub this next two weeks and was thinking about how you test a sub so that you can brag about how low it goes. Do you have to have a CD that lets you know?? for instance does it say"This is a 30Hz sine wave.....BBBBBBvvvvvvvWWWWWvbvbbbbwwwww"? I just am not sure how you guys have figured out how low your subs you have built or bought go. Thanks.
......and oh yeah if bizill is reading this, I did not try to piss you off in the post about fixing your rattley **** window.
Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes:
RTi10's Up Front
CSi5 Center
Post edited by drew spelts on
There are test disks you can buy that allow you to test your system. Avia and Video Essentials make great test disks. You can pick them up at Best buy.
Have fun
DanDan
Make your own test disc by downloading the test tones in the link below. keep in mind that by measuring your sub in your room is not telling you EXACTLY how deep your sub is playing because room gain will ramp up the low end. You'd have to take your sub outside and away from any boundaries to really get a sense as to how low it is playing.
http://www.snapbug.ws/sinewaves/Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
no worries. i did use the sinewaves and my house rattles down to 12 hz.drew spelts wrote:......and oh yeah if bizill is reading this, I did not try to piss you off in the post about fixing your rattley **** window.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
if you have enough sub be afraid. man the first time i put on 16-12 hz wave at a good volume it shook everything and took my breath away wow awsome.
