Computer sound problem
Early B.
More computer drama for Early B. (when it rains, it pours...)
I often record lectures to cassette from my computer. I have a boombox hooked to a Soundblaster Audigy 2 internal soundcard. Been working fine for the past couple of years. No problems. A few months ago I began to get some major static on my recordings. I changed out boomboxes and the static was still there. I even replaced the cable, but the static remained. I'm wondering if the problem could be my soundcard. Maybe a solder joint is loose or something.
Any ideas?
Thanks.
Any ideas?
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Sounds like a loose solder joint to me. Those jacks on sound cards aren't exactly notoriously strong, and they tend to get a lot fo stress, especially if you plug and unplug often.If you will it, dude, it is no dream.
That's a tough one, because it could be almost anything. Sounds like a connection problem to me, but that's just my best guess. Does moving the connecting cables seem to make any difference in the static?
Edit: And, what bobman said ^^^
Jason -
jcaut wrote:Does moving the connecting cables seem to make any difference in the static?
Static comes primarily out of one speaker. If I transpose the RCA connectors on my boombox, I get static from the opposite speaker.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
the problem lies in the connection.
Id also remove and reseat the sound card, use tuner cleaner on the 1/8" jack or rca what ever it has its the same as our stereo gear it corrodes and gets dirtyMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Thanks, fellas. Will do.
Waiting on a new internal CD burner to arrive, so I'll do it all at one time.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
