Computer sound problem
Early B.
Early B. Posts: 7,900
edited April 2024 in Clubhouse Archives
More computer drama for Early B. (when it rains, it pours...)
I often record lectures to cassette from my computer. I have a boombox hooked to a Soundblaster Audigy 2 internal soundcard. Been working fine for the past couple of years. No problems. A few months ago I began to get some major static on my recordings. I changed out boomboxes and the static was still there. I even replaced the cable, but the static remained. I'm wondering if the problem could be my soundcard. Maybe a solder joint is loose or something.
Any ideas?
Thanks.
"God grooves with tubes."
  • bobman1235
    bobman1235 Posts: 10,822
    edited December 2005
    Sounds like a loose solder joint to me. Those jacks on sound cards aren't exactly notoriously strong, and they tend to get a lot fo stress, especially if you plug and unplug often.
  • jcaut
    jcaut Posts: 1,849
    That's a tough one, because it could be almost anything. Sounds like a connection problem to me, but that's just my best guess. Does moving the connecting cables seem to make any difference in the static?
    Edit: And, what bobman said ^^^
    Jason
  • Early B.
    Static comes primarily out of one speaker. If I transpose the RCA connectors on my boombox, I get static from the opposite speaker.
  • POLKOHOLIC
    POLKOHOLIC Posts: 407
    the problem lies in the connection.
  • faster100
    faster100 Posts: 6,124
    Id also remove and reseat the sound card, use tuner cleaner on the 1/8" jack or rca what ever it has its the same as our stereo gear it corrodes and gets dirty
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Early B.
    Thanks, fellas. Will do.
    Waiting on a new internal CD burner to arrive, so I'll do it all at one time.
