Do LSi7s require much, if any break in?
rnp614
rnp614 Posts: 598
edited November 2005 in Speakers
I'm just curious...
Post edited by rnp614 on
  • okiepolkie
    okiepolkie Posts: 2,258
    I thought my first set of LSi7's sounded better after some break in. The ring radiating tweeter seems to benifit a noticable amount, but I didn't notice a huge amount on the woofer. The replacement woofers in my "new" 7's might still need a little time to break in. I haven't listened to them much and they seem to lack a little of the low end I remembered with my old ones.
    Tschüss
    Zach
  • McLoki
    McLoki Posts: 5,231
    Hard for me to put an hour figure on it, but they do take some time to break in. I was fairly dissapointed in the sound from the LSi7's upon first opening the box. Sounded much better after a week or so. (playing them 4 or so hours a night and 12 or so hours on the weekends. - mixture of radio and movies)
    Michael
  • rnp614
    rnp614 Posts: 598
    I feel like the highs are as they were with my 9s that were broken in, its just that the mids/lows seem really really thin. Thinner than my RTi38s by so much it seems unnatural. I'm thinking this woof needs to loosen up.
  • Early B.
    Early B. Posts: 7,900
    Yeah, those 7's will need some time to break in. Maybe 20-30 hours. Maybe more. I dunno. Hard to tell. Depends on your ear. However, you should experience a noticeable improvement over time.
    "God grooves with tubes."
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    you selling those RTi38 by chance - I have a friend desparately looking for some...
  • rnp614
    rnp614 Posts: 598
    Nope, they are now in my sister's care.
  • AsSiMiLaTeD
    ah well, can't find any on Ebay right now. He currently has some RTi28, but wants to move them to the back and get the 38 up front...
    /end derail
