Voice matching center
seaslug
seaslug Posts: 23
edited November 2005 in Speakers
Hey guys. My current surround sound setup consists of RT800i's (mains), a CS400i (C), Fx300i's (surrounds), and a PSW 450 (sub). On Friday, I'll be purchasing a 62" Mitsubishi DLP to replace my 36" Sony Wega. I'm excited about the TV, but here's my problem: In order to keep my CS400i, I'm going to have to construct some sort of shelf and mount it over the TV, because the new TV stand's shelves aren't tall enough (about 7" max) for the speaker (about 9" high), and the top of the TV (about 2" deep) certainly won't support it. As an alternative, I've thought about purchasing an RM7302 center channel (small, sleek, and can be pointed upward) to place below the TV, but I'm not sure how well it will blend with my other speakers. Replacing all the speakers is not really an option at this point because of the money I'll be shelling out for the TV. Any experience or opinions regarding pairing the RT's with the RM center? I think I probably know the answer, but I figured I'd come to the forum for validation. Thanks!
"The unexamined life is not worth living." -- Socrates
Post edited by seaslug on
  • Early B.
    Early B. Posts: 7,900
    Forget it. Just do the shelf thing or get a center channel speaker stand.
    "God grooves with tubes."
  • Maurice
    Maurice Posts: 517
    Best Buy has an omnimount unit made for lcd/dlp tvs to hold a center channel. Check out there site under tv mounts and its model #CCH1P. Sells for $31, I would have posted the link but I dont know how. :o
    Everytime I think I'm out, THEY PULL ME BACK IN!!!!!!
    Polk 70's,40,30's
    Velo DLS 3500 Sub
    JVC 61" HD-ILA
    Sony DA4ES AVR
    Oppo 981 DVD
    Sony CDP-CX235 CD
    Signal Bi-wires
    AR ProII IC's
  • leog
    leog Posts: 25
    Marantz SR5400 AVR 6.1
    Toshiba SD3750 DVD
    PSB Image 5T (fronts)
    POLK CSi3 (center)
    RTi4s (surrounds)
    PSW 404
    RTi4 (rear center)
