Voice matching center
Hey guys. My current surround sound setup consists of RT800i's (mains), a CS400i (C), Fx300i's (surrounds), and a PSW 450 (sub). On Friday, I'll be purchasing a 62" Mitsubishi DLP to replace my 36" Sony Wega. I'm excited about the TV, but here's my problem: In order to keep my CS400i, I'm going to have to construct some sort of shelf and mount it over the TV, because the new TV stand's shelves aren't tall enough (about 7" max) for the speaker (about 9" high), and the top of the TV (about 2" deep) certainly won't support it. As an alternative, I've thought about purchasing an RM7302 center channel (small, sleek, and can be pointed upward) to place below the TV, but I'm not sure how well it will blend with my other speakers. Replacing all the speakers is not really an option at this point because of the money I'll be shelling out for the TV. Any experience or opinions regarding pairing the RT's with the RM center? I think I probably know the answer, but I figured I'd come to the forum for validation. Thanks!
"The unexamined life is not worth living." -- Socrates
Post edited by seaslug on
Forget it. Just do the shelf thing or get a center channel speaker stand.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Best Buy has an omnimount unit made for lcd/dlp tvs to hold a center channel. Check out there site under tv mounts and its model #CCH1P. Sells for $31, I would have posted the link but I dont know how.
Everytime I think I'm out, THEY PULL ME BACK IN!!!!!!
Polk 70's,40,30's
Velo DLS 3500 Sub
JVC 61" HD-ILA
Sony DA4ES AVR
Oppo 981 DVD
Sony CDP-CX235 CD
Signal Bi-wires
AR ProII IC's -
try this nice little home made job
http://www.hometheatersound.com/features/diyhometheater/Marantz SR5400 AVR 6.1
Toshiba SD3750 DVD
PSB Image 5T (fronts)
POLK CSi3 (center)
RTi4s (surrounds)
PSW 404
RTi4 (rear center)
