volume is what?
Josh-S
What increases the volume? Watts? (powerconsumption?) Or more likly volts?
Just a curious question...
Post edited by Josh-S on
Voltage input...More later,
Tour...
Vox Copuli
watts = volts X amperage
increase any one of these and you get more volume.
then there are other formulas like work (in joules) = force (newtons) x distance (meters)
and power (watts) = work / time
These last two aren't too much related to audio but meh. -
Those are the equations, but shifting voltage potential is the process.
And my Sunfire is calibrated in joules...More later,
Tour...
Vox Copuli
EE's,
How does Ohms Law fit in there somewhere as far as current flow and voltage as electrical pressure along with the resistance are concerned? I have read this many times but seems I just dont write it in my own words clearly. Been 30 hears since my last electronics class. The gain knob allows for more voltage pressure to push more current and you get more watts which raises the amplitude of the wave so its louder. ehhh.
RT1 -
I just use the nob on the receiver.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Turn clockwise (to the right)for louder and counterclockwise (to the left) for softer.
Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
yea, but your a nut.!!
hey, I resemble that remark. (best curly voice)
Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
