volume is what?
Josh-S
Josh-S Posts: 160
What increases the volume? Watts? (powerconsumption?) Or more likly volts? :confused:
Just a curious question...
Post edited by Josh-S on
  • Tour2ma
    Tour2ma Posts: 10,177
    edited November 2005
    Voltage input...
    More later,
    Tour...
    Vox Copuli
  • michael_w
    michael_w Posts: 2,813
    watts = volts X amperage
    increase any one of these and you get more volume.
    then there are other formulas like work (in joules) = force (newtons) x distance (meters)
    and power (watts) = work / time
    These last two aren't too much related to audio but meh.
  • Tour2ma
    Those are the equations, but shifting voltage potential is the process.
    And my Sunfire is calibrated in joules...
    More later,
    Tour...
    Vox Copuli
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    EE's,
    How does Ohms Law fit in there somewhere as far as current flow and voltage as electrical pressure along with the resistance are concerned? I have read this many times but seems I just dont write it in my own words clearly. Been 30 hears since my last electronics class. The gain knob allows for more voltage pressure to push more current and you get more watts which raises the amplitude of the wave so its louder. ehhh.
    RT1
  • Skynut
    Skynut Posts: 2,967
    I just use the nob on the receiver.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Skynut
    Skynut Posts: 2,967
    Turn clockwise (to the right)for louder and counterclockwise (to the left) for softer.
    :D
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • reeltrouble1
    yea, but your a nut.!! ;)
  • Skynut
    Skynut Posts: 2,967
    hey, I resemble that remark. (best curly voice) :D
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
