Best receiver....
shawn474
shawn474 Posts: 3,052
Hello everyone. I may be posting in the wrong area, but just need some advice. I just purchased the polk rm-6005 speaker package to replace my huge floor speakers and am happy with them for the most part. I have a yamaha rxv595 receiver that i love, but may not be the best match. I am looking to upgrade to 6.1 receiver if it makes a noticable difference? Advice? And what is the best receiver option in the 400 dollar price range (if there is an option)? Thanks very much and appreciate any advice.
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
  • Ricardo
    Ricardo Posts: 10,634
    edited November 2005
    Welcome..
    You could try one of these:
    http://www.harmanaudio.com/search_browse/default.asp?sp=S&brand=HK
    Refurbished Harman Kardon;as good as new, great price, great service.
    SOPA
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    At your price point no sonic difference, save your dough, stick with the Yammie unless you want some new bells and whistles features it does not have.
    RT1
  • aaharvel
    aaharvel Posts: 4,489
    I respectfully disagree with reel. There is a sonic difference at that pricepoint between various receivers. HTrookie gave you a great starting point.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • unc2701
    unc2701 Posts: 3,587
    I'm gonna agree with you both. There are sonic differences, but it's hard to say one is better at that pricepoint- each one has it's own colorations and depending on your ear some will be more/less pleasing to you.
    Backburner:Krell KAV-300i
  • shawn474
    I really appreciate everyone's advice. I am a newbie to the audiophile fix - I started out with the receiver when it first came out and spent 500 dollars for it (almost seven or eight years ago). I listen to a lot of music and watch a ton of movies and football on sundays. The polks sound great, but lack the "boom" that I got with my cerwin vega d5's and infinity studio monitors. Those became too big and with a toddler learning to walk I was afraid that she would pull them over and hurt herself. I was just wondering whether or not it would be worth it to upgrade to 6.1 and get a new receiver. Thaks again for the input and I look forward to anyone else's opinions.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • reeltrouble1
    yes, Unc. agreed, they might sound different but not better or worse so why waste the dough unless he wants more channels or something. Athough all the mass market entry level Asian receivers have a bright to some, harsh to others sound to them. Not suprising since all the Asian piano's like Yamaha, Wang, Akai, are also bright compared to say a Steinway. Entry level is just that. Its just they way it is. ie non-discreet circuity, cheap caps, power supply, everthing in one box, heat, yada yada the science guru's can explain it I just hear it.
    Andrew and HT well its OK to disagree and I dont mean to rip or dis ya, everbody has budget or like in this case safety concerns but there is a whole world of audio levels, your next level, oh say Rotel, NAD, Outlaw, then maybe B&K, Sunfire, Parasound, its gets mixed at the mid level gear but these are definetly seperated from the pack. Some of these are now even from the far east but just better.
    Then speaking of Seperates :D
    Its audio its fun.
    RT1
  • aaharvel
    What I meant by sonic difference was not quality, but for the type of sound the listener prefers. Bright, Warm, Scrambled, Over-Easy, etc..
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • Mike682
    Mike682 Posts: 2,074
    I would stay 5.1 or upgrade to 7.1. I'm just not sure about 6.1's future. I think the industry will skip 6.1 and record movies in 7.1 down the road, making 7.1 the mainstream like 5.1 is now.
    How do my fellow polkies feel about 6.1's future???
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • aaharvel
    imo it has no future.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • cfrizz
    cfrizz Posts: 13,415
    There are plenty of choices in that price range. Either look for one that has all the features you want and sounds the best to you. Or if it is more boom you want, look into getting a new sub.
    One of these from here:http://svsubwoofers.com/subs_pb10_isd.htm
    Or one of these from here:http://www.outlawaudio.com/products/lfm1.html
    http://www.outlawaudio.com/products/lfm2.html
    Welcome to the club Shawn!
  • Nate79
    Nate79 Posts: 25
    what movies are in 7.1?
  • reeltrouble1
  • aaharvel
    zero. use the processing in avr.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
