Opinions on the PSW505 VS....
fab5valentine
fab5valentine Posts: 84
edited November 2005 in Speakers
Hello,
I read a lot of reviews on HSU, SVS and Velodyne and have been leaning towards a SVSPB12ISD/V..
I have just talked to an authorized dealer where I can get a PSW505 for $364 shp'd to my door.. Full warranty etc..
Can I go wrong? My listening space is ~18x22' but connected to another open space of the same or bigger dimensions. I need to upgrade from my PSW350.. Should I save my dough and go with one of the above listed, or will I be okay.. My fronts will be RTi6 or 4's (or i28's) with a CSi3 (or CSI30) center, and rears wil be RTi4's (or i28's) or TC series in ceilings.. Currently running a Denon 2802..
Any pro's and cons on the PSW505 will be appreciated!
fab5valentine
-fab5
Klipsch RB81's/RC62/RS52's
SVS PB12+/2
Denon 3808CI
Panasonic BD60
Toshiba 56MX195 1080p
Post edited by fab5valentine on
  • fab5valentine
    Perfect info.. That's exactly along the lines I was looking for..
    fab5valentine
    -fab5
    SVS PB12+/2
    Denon 3808CI
    Panasonic BD60
  • steveinaz
    steveinaz Posts: 19,546
    Just like I wouldn't buy an SVS bookshelf speaker over a Polk; I wouldn't buy a Polk subwoofer over an SVS. The each have their niche.
  • faster100
    faster100 Posts: 6,124
    I'll bet the 505 kicks ****, I had a 404 and it was just, OK.. The SVS on the other hand wont leave you second guessing. Its a solid sub at any of their levels.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
