Opinions on the PSW505 VS....
fab5valentine
Hello,
I read a lot of reviews on HSU, SVS and Velodyne and have been leaning towards a SVSPB12ISD/V..
I have just talked to an authorized dealer where I can get a PSW505 for $364 shp'd to my door.. Full warranty etc..
Can I go wrong? My listening space is ~18x22' but connected to another open space of the same or bigger dimensions. I need to upgrade from my PSW350.. Should I save my dough and go with one of the above listed, or will I be okay.. My fronts will be RTi6 or 4's (or i28's) with a CSi3 (or CSI30) center, and rears wil be RTi4's (or i28's) or TC series in ceilings.. Currently running a Denon 2802..
Any pro's and cons on the PSW505 will be appreciated!
fab5valentine
fab5valentine
-fab5
Klipsch RB81's/RC62/RS52's
SVS PB12+/2
Denon 3808CI
Panasonic BD60
Toshiba 56MX195 1080p
SVS PB12+/2
Denon 3808CI
Panasonic BD60
Post edited by fab5valentine on
Perfect info.. That's exactly along the lines I was looking for..
fab5valentine-fab5
SVS PB12+/2
Denon 3808CI
Panasonic BD60
Toshiba 56MX195 1080p -
Just like I wouldn't buy an SVS bookshelf speaker over a Polk; I wouldn't buy a Polk subwoofer over an SVS. The each have their niche.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I'll bet the 505 kicks ****, I had a 404 and it was just, OK.. The SVS on the other hand wont leave you second guessing. Its a solid sub at any of their levels.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
