Need quick help with our Jetta
audiobliss
We (Dad) dropped the radiator cap to our 2002 Jetta TDI, and it's laying on the top of the undercarriage skid pad/protector whatchamacallit. I can't get to it from above, and I can't seem to whack the skid pad right to make the cap slide near the edge, so we're thinking about taking it off. There appears to be about 7 screws holding it on, and then it looks like it should just slide off. The question is, where under the car can you jack it up? There's not enough space under there to do it without having the car jacked up, and I don't see anywhere under there that looks like it'll take a jack.
Any help would be much appreciated!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Where the struts mount."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Thanks. I'll look there.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
From my experience most german cars have a spot just behind the front tires on the sides that are intended as the lift point. On my bimmer it was right at the leading edge of the front door. Might be slightly different for VW. If you have the manual it should tell you for sure.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
cmy330go wrote:From my experience most german cars have a spot just behind the front tires on the sides that are intended as the lift point. On my bimmer it was right at the leading edge of the front door. Might be slightly different for VW. If you have the manual it should tell you for sure.
That too."SOME PEOPLE CALL ME MAURICE,
Maybe try one of those magnets attached to a an extendable antenna thingamajiggy. Can be bought in auto stores or home supply stores for a few bucks.Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
Well, I went running outside to tell Dad so we could get started, and he was gone! I called him and he said he was on the way to the VW dealership to buy another cap.
:rolleyes:
I suppose we'll still have to get the old one out of there.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
I looked along the edge of the car, but I (with my admittedly unexperience eye) didn't see anywhere that looked like it'd support a jack.
Also, the cap is a huge plastic piece, so my magnet wouldn't work.
Thanks for the responses!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
