No pre-amp at all??
I've always been under the impression that an amp is always full out and the pre regulates the amps output. Unless the amp has gain controls, like both of my amps, and they are not turned all the way up.
I'm probably under the wrong impression, though :rolleyes:
"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
^^ That's how I've always understood it.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
a few months ago i ran my CDP directly to my monoblocks and the volume level was not anywhere near what the amps are capable of so i think the amount of volume is directly tied to the output capability of the source component.thanks....WCW IIIND13 wrote:I've always been under the impression that an amp is always full out and the pre regulates the amps output. Unless the amp has gain controls, like both of my amps, and they are not turned all the way up.
Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
Ahh, I think I just figured it out. When you turn on the amps with no preamp or with the preamp off, the amp/s are wide open. The preamp then changes the volume by cutting back on the signal going to the amps. The preamp either lessens the signal or adds gain to the signal from the source, thus changing the volume. However, when you hook a source up directly to the amps, you have no control over the gain and thus the volume. The output voltage of the source dictates the volume.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
oh i cant do that
my amps direct inputs still have the volume contrler on them , i once accedentely put the outputs in the inputs and then there was no volume . (made me jump wen i went to put on a movi ) lucky it still works.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
lanion wrote:No preamp would basically mean everything plays at what would be 0db on a preamp... right?
yes that is so isnt it?ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
My understanding is that if the source component (Cd Player, Tuner, etc) has enough output to drive the amp to full capacity, then it will; but, if the amp requires more source signal than the source can provide to attain full output, that's when an active preamp would be needed to give the necessary boost (gain) to allow the amp to reach full output. I've just never heard of running a line source directly into an amp at full output before. I'd be scared as hell to hit the "play" button, thinking my speakers were about to be sent into orbit.
Then again, I could be full of ****.
Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
This is more the idea that you set the volume to the correct level for some loud rock and tell yourself you can not change it. Problem there is that if I had done it that way I would have ended up changing it and would never have experienced what I did. That's why I suggested removing the pre.
How about this, put some good lively rock on and enjoy it for awhile. Wherever you end up at with the volume control, leave it there for the next few listening sessions and don't change it no matter what.
Sounds like a good way to damage your hearing. :eek:
Shack has it right, sit down, shut up, and listen to the damn music!!!!
Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
alot od cdp`s have an adjustable output on them..Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
I live in a house with three women. This is a phrase I am unaccustomed to hearing from a woman. I need to savor this moment as it may never happen again.cfrizz wrote:Shack has it right"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Max--
Ok...I get it. Play all my music loud, I do that ALL THE TIME....You're right it is cool...LOLSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
:eek: :eek: :eek:
WAAAAAAAAAAAAAAAA!!!!!shack wrote:I live in a house with three women. This is a phrase I am unaccustomed to hearing from a woman. I need to savor this moment as it may never happen again.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Cathy
I think you made shack-daddy's day!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
LOL! I guess so!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
on my AVR o dB is good its loud enought but not distorted, but my neigbur spent over £700 on a in car system and his -20 dB was starting to badly distort wheras i listen to mine at about -20 to -10 dB most of the timeELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
The lack of control was the same as when you listen to music in a club, stadium or someones basement band.
Sorry, but I've got to disagree with this. Most every live event I've been to, the sound is HEAVILY managed to include the volume.
The volume of the record without attenuation, IMO, is heavily dependent on engineering so I'm not with the 'it gets you closer to live' line of thought.
Now, to remove a link in the chain and all that particular piece brings to the party, sure. However, I've got to have control of the volume for a myriad of reasons.
The point (which everyone seems to be missing), is that YOU have no control over it.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
No, I get that but I don't see the higher fidelity aspect in that.
I think it's more the fact that since you have no control over it, you soon forget about it and start focussing on the sound more, instead of the volume.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Maybe I'm different but if the music is not at a level that I want it to be at, I don't want to listen.
Different strokes for left handed people, no big deal.
Troy (and others), it wasn't suggested as a permenant 'fix', just something to try. A release of control. It wasn't a campaign to 'get rid of your preamps, you dont need them', or a poll to see what people thought about preamps - it was an excercise in audio, that's all.
Try it.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
audiobliss wrote:I think it's more the fact that since you have no control over it, you soon forget about it and start focussing on the sound more, instead of the volume.
FINALLY! SOMEONE GETS IT.
I've got the afternoon off and noone at the hacienda, so when I get home, I'm gonna throw on DSOM and take the MLP out of the chain and see how it does.
Nevermind, re-read the post...2V or something like that..
I didn't really think it was a campaign to get rid of pres....I was just posting my thoughts about the premise..
No biggie
RuSsMaN wrote:A release of control. Try it.
Hmmm...
Me personally, I'll stick to taking the preamp out of the circuit.
Stay tuned for my next experiment: Audio systems with interconnects, speaker wires and power cables disconnected. I expect a lot of noise to go away.
madmax wrote:Stay tuned for my next experiment: Audio systems with interconnects, speaker wires and power cables disconnected. I expect a lot of noise to go away.
madmax
I tried this once. The W.A.F. is OUTRAGEOUS!
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
No biggie Troy, I was 'just sayin' broham.
Yeah Noel, I've got some CD8b manuals somewhere, I'll see what it is exactly. It was much louder than the Cal Audio running them without a DAC - through the DAC it made no difference which CDP was hooked up.
Chuck, I was going to suggest running with all the tubes removed - but you might be onto something with the cables.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
