I goofed..
polkatese
So, this afternoon UPS dropped the Gemstone Blue Diamond amplifier. I completely underestimate the size of this beast. It weigh 83 freakin' lbs naked. I managed to carry it from the garage to the living room myself, but it was a beatch! and then, when I remeasured the in-wall shelf where it supposed to slide in, I figure I can have it protruding a bit in the front side. The beast depth is 22" and with banana plugs, it will be more like 24". Somehow when I ordered it, I thought I can make it work, and I was wrong!
I knew I was in trouble the minute I cracked open the box. Clearly, I need to come up with a different plan, since I don't think the shelf will be able to support its weight. Any suggestion?
PS: I have attached a couple pics to give you an idea on the size.
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
I can hold it for you until you find a spot to put it..........
scott -
Hmm. Sounds like you're in a whole heap of trouble. You just need to send it to me and get this whole thing over with.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
That beast looks awesome! got a quick link for some specs?***WAREMTAE***
Whats the specs on that beast??
edit-Henry, great minds think alike, huh??
"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
I heard nothing but praise on this beast. Here is the link:
gemstoneaudio.com
I was told by the owner that they managed to pass cost saving to customer, since they don't have to do extensive CE certification and testing, for North America market - and factory direct. So, only NAFTA residents can get one..:)
specs should be on the site url above. I am not kidding, this is a beast, can't wait to hook it up, except it won't be tonight.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
This looks like an idea solution for people who complain about their subs skipping across the floor. A subwoofer weight if you will...
Very nice polkatease! Looking forward to your review on the wee beastie.
regards
DaveTime is the best teacher. Unfortunately it kills all its students. -
yeah, it would really be an effective door stopper/sub weight
I'll compare the beast with B&K 125.7, so, review will come along...I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
weld in some structural I-beams into your shelf and n-joy!
ps.......don't forget the 3/4 inch anchor bolts!
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
looks like it deserves an amp stand of it`s own...Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
take a line from svs on their pb12-plus/2...."you can even use your amp as an end table."
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
Holy ****...that's big! :eek: As they said in Jaws, "We're going to need a bigger boat, right?"2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Wow killer amp . Damn no shelf to put it on. Thats ok Bro , send it here my rack will hold it allday. I will also go as far as giving it a great reveiw. If you want to send the B&K as well, I'll conduct the shootout.
Good going Bro,
DanDan
I removed the hinges on the in-wall cabinet. It looks like it might work, sitting on the very bottom base. I just need to rearrange the gears around, Panamax unit will need to sit on top of the amp. I guess it will become a weekend project.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
hey polka, you gonna run fans, or is the shelf wide open toward the front at minimum?
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
Does that amp have wheels on the back?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
well, one of the criteria that I passed along to Gemstone, is that, it has to run really cool. I have a fan installed, but mainly for the modded CDP (it runs really warm/hot). It was confirmed that this beast will run pretty cool, because it has pretty extensive cooling fins. We'll see how it goes, this weekendI am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
don't drop it! get some help movin' that sucker around. my friggin' 7300 is supposed to weigh like 65 lbs or something and it played games with my wrists. had to hoist it above chest level. fun, fun. yours comes in at like 84 lbs? :eek:
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
no ****. I carried it from the garage to the living room by myself, grabbed it by the fins, works great, but my wrists are still sore. Chunk of metal, that for sure.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
damned cumbersome boxes!
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
I think what we have here is a case study in when it makes sense to have xlr's- put that **** in a room of its own.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Good heavens. What a beast. Lets get an **** shot of that thing.
Shizelbs wrote:Good heavens. What a beast. Lets get an **** shot of that thing.
yes please. perfect timing as this 83 lbs "naked" beast is, well, naked.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
Here is the stock pic of the ****-end.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
SCompRacer wrote:Does that amp have wheels on the back?
A very good suggestion, kinda like the wheely computer bag, and a foldable handle.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
polkatese wrote:A very good suggestion, kinda like the wheely computer bag, and a foldable handle.
The Rotel RB-1090 I had weighed 84 pounds and had wheels on the back. Made it easy to slide into a rack. One did have to watch for the fins on the front. They could leave an unwanted impression in the forearms.
I'm anxious to hear what you think of it.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
So, here is what I ended up have to do. It works relatively well, not the best, but it works.
Initial impression of the sound: at lower volume, I get all the details from the Cremona. I would characterize it as weighty (no pun intended), and detailed, and I really do feel the energy even at the low volume, compared to the B&K. There are some more listening time to do, and I'll post some more, if anyone care.
It's a clear upgrade from the B&K, even though we all know that an amp is an amp is an amp..
ps: it took me almost 3 hours to hook up the XLR, positioning, rearranging this beast, and the bruises I have is my proof.
I cannot even fathom how big that thing is. That B&K pre must be pretty large (possibly as big as my receiver?), and that amp dwarfs it! That's amazing!
And I'd personally like to know just how much you think it sounds like every other amp out there.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
are you running all XLR`s..?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
audiobliss wrote:I cannot even fathom how big that thing is. That B&K pre must be pretty large (possibly as big as my receiver?), and that amp dwarfs it! That's amazing!
yes, that's why the title of thread is I goofed!
the mother load of any amp in my lifetime, with the exception, perhaps, one day I'll get to own Levinson monster mono block..
Bear, I used all XLR. The thought is: I have it, why not? especially with the way the snake pit is designed, I could as well put an AM radio back there, and I might get Radio China
:eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
