Polk PSW202/303/404 vs. Infinity BU2
shawn474
shawn474 Posts: 3,052
I recently got a set of polk rm6005 speakers to replace my cerwin vega D3 and Infinity sm115 floor speakers. I did this because we have an infant who likes to climb on things and I was afraid of her pulling up on the speakers and them falling on her. I realize that I won't get the same sound from the RM6005 due to many reasons, but my question is this. I hooked up the satellites to my infinity BU2 sub in order to bypass the low frequency filter. Would it sound any better if I were to get the PSW series sub than with the infinity sub.? Overall, I am happy with the sound part, but looking to tweak things a little bit in order to get the full effect out of these speakers. Thanks for any responses.
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
  • okiepolkie
    okiepolkie Posts: 2,258
    edited November 2005
    Welcome to the forum. Overall, you probably won't get an incremental increase with the subs you mentioned. The 404 might be a little above it, but you most likely won't notice much of an increase.
    Take a look at www.svsubwoofers.com or www.hsuresearch.com. For about the same amount of money, you can get a better subwoofer. The svs pb10-isd is pretty good for its price.
    Enjoy the new speakers. I had to go from bookshelf speakers on stands to something else as well when my boy came along.
    Zach
    Tschüss
    Zach
