Physics question
  • petrym
    petrym Posts: 1,912
    edited November 2005
    I'm withholding my answer until this one gets settled: Chemistry/math problem quick help :D
    :p
  • Ricardo
    Ricardo Posts: 10,634
    No difference; both ropes will have the same strength and break with the same load.
    Because I know. :)
    SOPA
  • beardog03
    beardog03 Posts: 5,550
    so what did teach say..?
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • HBombToo
    HBombToo Posts: 5,256
    The shorter rope would support more weight than the longer because the longer rope would actually be heavier than the shorter thus decreasing the total.
    Sounds like me and ND's physics lessons from 20 years ago stuck... must be due to the increased length of beer drinking time :>)
    ***WAREMTAE***
  • Sami
    Sami Posts: 4,634
    organ wrote:
    Let's see... When I used to smoke up, I rolled long and short joints. While smoking, the longer joint would sometimes loose it's stiffness and bend towards the ground a little. Never had this problem with short ones. And I'm talking same rolling paper/same weed here.
    That thing you rolled would be of horizontal length while the rope would be vertical, different things. :)
  • unc2701
    unc2701 Posts: 3,587
    With a perfect rope in a vertical orientation the only difference is the weight of the longer rope- thus the shorter rope can hold more weight.
    In the real world, you have additional factors:
    1)Statistically the probably of failure is greater on the longer rope, because it has a greater number of failure points. let's say the average breakage level at a point is 10 pounds- however, some are 12 lbs, some are 8lbs... and some are 6lbs- you're more likely to see that six pound one in a longer rope.
    2)you never have a perfect vertical load and the longer the rope, the more leverage can be exerted to cause a failure.
    Backburner:Krell KAV-300i
  • Tex
    Tex Posts: 189
    I say they are the same. I think rope strength is determined by material and circumference, not length. But what do I know, I'm new to this forum and I still have a lot to learn :)
  • audiobliss
    audiobliss Posts: 12,518
    The physics teacher said that there is no difference in their 'weight-holding-capablities'. They exactly the same.
    So,......I was wrong.....*sigh* :(
    :p
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Polkersince85
    Polkersince85 Posts: 2,883
    Good explanation of tensile strenght.
    http://en.wikipedia.org/wiki/Tensile_strength
